[mapserver-users] What is the default coordinate system used in MapServer (if no projection is defined)?
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Mon Jun 2 15:50:53 PDT 2014
MapServer has no default, it's just uses a simple Cartesian coordinate system. HOWEVER, the CGI does have some hooks that tries to auto-detect lat/lon coordinates and automatically convert them to what's set in the MAP's projection block. I believe that only kicks in if there is a projection block defined.
How'd you trigger the message?
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Basques, Bob (CI-StPaul)
Sent: Monday, June 02, 2014 5:40 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] What is the default coordinate system used in MapServer (if no projection is defined)?
All,
So I was trying to just display some data without a coordinate system assigned. And I ended up eventually getting a LAT/LON (out of range) error. Once I set the projection in the MAP block to something resembling a XY projection, all was well.
I suspect that LAT/LON is the default? Is there a way to do something other than what I did to use simple Cartesian coordinates?
Bobb
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140602/2da35494/attachment.html>
