[mapserver-users] Data Query Issue
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Fri Jun 6 12:18:03 PDT 2014
Eric,
Add a PROJECTION/END block inside of Each layer (based on the raw data projection for each layer) and another at the map level for the projection you want to use for queries. Mapserver will just transform the locations for you on the fly when you make a query.
Bobb
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Weisbender, Eric
Sent: Friday, June 06, 2014 1:56 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Data Query Issue
Hello list,
I am auto downloading two different sets of fire point data. One comes in Geographic WGS84 the other in Geographic NAD83. When I draw both at the same time and try a Query by Rectangle only the last one defined in the mapfile returns info. If I reproject one to UTM then they both return information. This is an auto download every two hours so I would hate to have to mod the data. I'm using version 6.2.1. Query by point works fine. Any ideas are greatly appreciate.
Thanks
Eric
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140606/8d20779d/attachment.html>
