[mapserver-users] WMS-T support for vector data using OGR
Even Rouault
even.rouault at mines-paris.org
Mon Jun 9 12:34:02 PDT 2014
Le lundi 09 juin 2014 21:15:05, Hari Pradhan a écrit :
> Hello List,
> I have been trying to implement MapServer WMS -T using tile index. But I am
> not able to make it work. I made some changes to the mapfile defined for
> "WMS-T for raster imagery" in the link
> "http://mapserver.org/ogc/wms_time.html" to make it work for vector data
> and followed the post in the link "
> http://osgeo-org.1560.x6.nabble.com/WMS-WFS-and-yearly-time-dependent-data-
> td4275270.html", but it didn't fix it out.
> The thing that I did:
> 1. I had a set of vector shape file captured at different time frame. Say
> v1.shp, v2.shp,...
> 2. I used ogrtindex to generate a tileindex (say 'VectorLayer2.shp) for
> above shape files. The dbf file of this tileindex has 'location' attribute.
> 3. I ran my script to add 'Time' field to this tileindex such that the
> final dbf file has two fields as location and Time.
> My dfb file looks like:
> LOCATION Time
> C:\data\tif\VectorLayer\SiteAddress_1.shp,0 20070301
> C:\data\tif\VectorLayer\SiteAddress_2.shp,0 20070302
> 4. Then finally I wrote the map file with layer section as:
> LAYER
> NAME "states"
> DEBUG 5
> CONNECTIONTYPE OGR
> TILEINDEX "VectorLayer2.shp"
> TILEITEM "Location"
> TYPE POLYGON
> STATUS ON
> METADATA
> "wms_title" "states"
> "wms_include_items" "all"
> "wms_dataurl_format" "text/HTML"
> "ows_include_items" "all"
> "wms_exceptions_format" "application/vnd.ogc.se_xml"
> 'wms_srs' 'EPSG:42304'
> "wms_timeextent" "20070301/20070302"
> "wms_timeitem" "Time"
> "wms_timedefault" "20070302"
> END
> FILTER "Time = '20070302'"
> PROJECTION
> "init=epsg:42304"
> END
> CLASS
> NAME "The Upper Great Lakes States"
> STYLE
> COLOR 232 232 232
> OUTLINECOLOR 32 32 32
> END
> END
> END
> By doing this, I got the following error.
> msOGRLayerInitItemInfo(): OGR error. Invalid Field name: Time".
> Could anyone please help me to resolve this problem?
Hum, I'm wondering if FILTER "Time = '200070302'" doesn't apply to the
shapefile referenced by the tileindex, instead of the tileindex itself. Perhaps
you could try to remove it ?
Also you could try to seperate a layer with the tileindex itself and the
vector layer using it, as in the example in
http://www.mapserver.org/ogc/wms_time.html
> Thanks in advance.
> Thanks
Geospatial professional services
http://even.rouault.free.fr/services.html
