[mapserver-users] WMS-T support for vector data using OGR
Even Rouault
even.rouault at mines-paris.org
Mon Jun 9 13:29:47 PDT 2014
Le lundi 09 juin 2014 22:15:56, Hari Pradhan a écrit :
> Thanks Even. I tried as you said by separating a layer with the tile index
> and the vector layer as:
> # Tile Index
> LAYER
> STATUS ON
> NAME "time_idx"
> DATA "vector2.shp"
> TYPE POLYGON
> #CONNECTIONTYPE OGR
> END
> LAYER
> NAME "states"
> DEBUG 5
> TYPE POLYGON
> TILEINDEX "time_idx"
> TILEITEM "Location"
> STATUS ON
> METADATA
> "wms_title" "states"
> "wms_include_items" "all"
> "wms_dataurl_format" "text/HTML"
> "ows_include_items" "all"
> "wms_exceptions_format" "application/vnd.ogc.se_xml"
> 'wms_srs' 'EPSG:42304'
> "wms_timeextent" "20070301/20070302"
> "wms_timeitem" "Time"
> "wms_timedefault" "20070302"
> END
> #FILTER "Time = '20070302'"
> PROJECTION
> "init=epsg:42304"
> END
> CLASS
> NAME "The Upper Great Lakes States"
> STYLE
> COLOR 232 232 232
> OUTLINECOLOR 32 32 32
> END
> END
> END #Layer
> This also gives an error as "msDBFGetItemIndex(): DBASE file error. Item
> 'Time' not found.".
Looking at the code of msTiledSHPNextShape(), I believe that your shapefiles
reference in the tile index should also have a "Time" field.
> On Mon, Jun 9, 2014 at 2:34 PM, Even Rouault <even.rouault at mines-paris.org>
> wrote:
> > Le lundi 09 juin 2014 21:15:05, Hari Pradhan a écrit :
> > > Hello List,
> > > I have been trying to implement MapServer WMS -T using tile index. But
> > > I
> > am
> > > not able to make it work. I made some changes to the mapfile defined
> > > for "WMS-T for raster imagery" in the link
> > > "http://mapserver.org/ogc/wms_time.html" to make it work for vector
> > > data and followed the post in the link "
> > http://osgeo-org.1560.x6.nabble.com/WMS-WFS-and-yearly-time-dependent-dat
> > a-
> > > td4275270.html", but it didn't fix it out.
> > > The thing that I did:
> > > 1. I had a set of vector shape file captured at different time frame.
> > > Say v1.shp, v2.shp,...
> > > 2. I used ogrtindex to generate a tileindex (say 'VectorLayer2.shp) for
> > > above shape files. The dbf file of this tileindex has 'location'
> > attribute.
> > > 3. I ran my script to add 'Time' field to this tileindex such that the
> > > final dbf file has two fields as location and Time.
> > > My dfb file looks like:
> > > LOCATION Time
> > > C:\data\tif\VectorLayer\SiteAddress_1.shp,0 20070301
> > > C:\data\tif\VectorLayer\SiteAddress_2.shp,0 20070302
> > > 4. Then finally I wrote the map file with layer section as:
> > > LAYER
> > > NAME "states"
> > > DEBUG 5
> > > CONNECTIONTYPE OGR
> > > TILEINDEX "VectorLayer2.shp"
> > > TILEITEM "Location"
> > > TYPE POLYGON
> > > STATUS ON
> > > METADATA
> > > END
> > > PROJECTION
> > > "init=epsg:42304"
> > > END
> > > CLASS
> > > STYLE
> > > COLOR 232 232 232
> > > END
> > > END
> > > END
> > > By doing this, I got the following error.
> > > msOGRLayerInitItemInfo(): OGR error. Invalid Field name: Time".
> > > Could anyone please help me to resolve this problem?
> > Hum, I'm wondering if FILTER "Time = '200070302'" doesn't apply to the
> > shapefile referenced by the tileindex, instead of the tileindex itself.
> > Perhaps
> > you could try to remove it ?
> > Also you could try to seperate a layer with the tileindex itself and the
> > vector layer using it, as in the example in
> > http://www.mapserver.org/ogc/wms_time.html
> > > Thanks in advance.
> > > Thanks
> > Geospatial professional services
> > http://even.rouault.free.fr/services.html
