[mapserver-users] Question about config Mapserver to provide SOS service from postgis table/view
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Jun 15 12:18:53 PDT 2014
On 6/15/2014 2:16 PM, Miguel-Angel Manso-Callejo (UPM) wrote:
> Dear all,
> I'm trying to config mapserver to offer through SOS data stored in two
> tables joined by a view.
> I'm trying to offer in the first step only one time serial data and i'm
> using this configuration:
> LAYER
> NAME "test_sos_layer"
> METADATA
> "sos_procedure" "vaporcolumna" ## REQUIRED
> "sos_procedure_item" "vap"
> "sos_offering_id" "MADR13407S012" ## REQUIRED
> "sos_timeitem" "fecha"
> "sos_observedproperty_id" "vap"
> "sos_observedproperty_name" "Vapor_agua_columna"
> "sos_offering_timeextent" "2010/2014"
> "sos_describesensor_url"
> "http://138.100.61.23:90/sensorml/MADR13407S012.xml" ## REQUIRED
> "sos_offering_name" "GPS Station in Madrid 13407S012"
> END
> TYPE POINT
> STATUS ON
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=127.0.0.1 port=5432 dbname=example_postgis21
> user=postgres password=postgres"
> DATA "pos, vap from vaporcolumna where id='MADR13407S012' "
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> NAME "vap"
> STYLE
> COLOR 255 0 0
> SYMBOL "circle"
> SIZE 8
> END
> END
> END
> View have this fields:
> Id (pk), pos (geometry), vap (double), fecha (date)
> Can any one help me informing what i'm doing bad or how must i config in
> order to do it?
You probably need to make sure pos is listed in the geometry_columns
table and associated with your view.
Turn on layer debugging and set DEBUG 5
try to use shp2img so see the log messages and any error messages.
-Steve W
