[mapserver-users] Capabilities / queryable GROUPed layer
b.j.kobben at utwente.nl
Mon Jun 16 10:59:45 PDT 2014
Just checking: you did make sure that each LAYER has TOLERANCEUNITS and
TOLERANCE values, and a TEMPLATE in each CLASS (as required by Mapserver
to make a layer queryable)...?
Barend
On 11-06-14 18:07, "Lars Lingner" <gislars+list at googlemail.com> wrote:
>Hello,
>I'm out of ideas configuring a WMS with grouped layers for a
>GetFeatureInfo-Request. The problem is, in the capabilities document at
>the layer level ...queryable="1"... is missing. The actual gfi request
>is working.
>Since my client is processing the capabilities doc and is looking for
>queryable layers, I had to work around with a static capabilities
>document.
>My search resulted only in an old ticket [1], but maybe this isn't
>related.
>Can someone here confirm or deny this issue?
>/usr/lib/cgi-bin/mapserv -v
>MapServer version 6.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
>SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>SUPPORTS=SVG_SYMBOLS SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
>SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR
>INPUT=GDAL INPUT=SHAPEFILE
>OS: Ubuntu 12.04
>Best wishes,
>Lars
>[1] http://trac.osgeo.org/mapserver/ticket/3931
>_______________________________________________
>mapserver-users mailing list
>mapserver-users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
