[mapserver-users] color attribute question
Carlos Ruiz
boolean10001 at yahoo.com
Mon Jun 23 08:13:29 PDT 2014
Do,
If you want to do this without using mapscript, you can pull the gradient calculation as an attribute from your data table.
ALTER TABLE mytable ADD COLUMN gradient_color VARCHAR;
UPTATE mytable SET gradient_color = floor(gradient * 255)::text || ' 0 0';
Cheers
Mtro. Carlos Ruiz
On Monday, June 23, 2014 4:59 PM, "Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us> wrote:
You can compute a color string using PostgreSQL string functions:
SELECT percentage || ‘ 0 0’ AS color FROM …
Steve
From:mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Do Wi
Sent: Sunday, June 22, 2014 3:50 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] color attribute question
hi!
i have this scenario:
i have a column in my postgis table which contains a double representing a percentage.
i want to color my polygons in a gradient fashion based on that number.
the docs states three ways to specify color:
1. three [1-255] numbers
2. hex string
3. [attribute]
but the attribute must be a string by itself in the same format as options 1 or 2.
how can i achieve something like
COLOR [percentage]*255 0 0
or
COLOR [percentage] 0 0
if percentageis already 0..255
for a red gradient for example?
thanks allot!
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140623/99dfb724/attachment-0001.html>
