[mapserver-users] PostGIS Connection Failure
Krishna Priya Patury
krishna.patury at gmail.com
Tue Jun 24 06:35:39 PDT 2014
Just wanted to add, when I do a service iptables status, it is says
Firewall is not running.
On Tue, Jun 24, 2014 at 9:30 AM, Krishna Priya Patury <
krishna.patury at gmail.com> wrote:
> Hi All,
> Any other ideas?
> The map server application installed outside of my Centos VM can connect
> to the Postgres database on the VM. I can also connect to the database both
> from within and outside the VM using psql.
> I believe the Mapserver installation on my VM is fine too as my shp2img
> and running the mapserver through command line work just fine. The issue is
> only when I try to connect to the database through the application from my
> VM.
> I do not see anything additional in the logs. I can see that the database
> logs are not updated when I hit it though the application within the VM,
> understandably so with the error message in the browser.
> The only difference between running shp2img and the application is perhaps
> the user? I was able to open a succesful connection through psql as an
> 'apache' user as well(User which is running the Apache server). So am not
> sure what is missing.
> Thanks,
> Krishna.
> On Mon, Jun 23, 2014 at 5:24 PM, Krishna <krishna.patury at gmail.com> wrote:
>> Yes I can connect to Postgres using the same connection information
>> through psql both from within and outside my vm.
>> Sent from my iPhone
>> > On Jun 23, 2014, at 5:20 PM, Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>> > Did you restart your postgresql after making the changes to pg_hba and
>> postgresql.conf? Can you telnet to port 5432? Can you connect with psql?
>> Just ignore mapserver for now, you have a connection issue.
>> > P.
>> > http://postgis.net
>> > http://cleverelephant.ca
>> > On June 23, 2014 at 2:17:19 PM, Krishna (krishna.patury at gmail.com)
>> wrote:
>> >>> As I mentioned I have disabled the firewall. Or so I think. When
>> >> I login as 'root' and click firewall it says disabled. Any way
>> >> I can confirm/ test this?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140624/03aa8e49/attachment.html>
