[mapserver-users] SIZEUNITS set to meters
Kalbermatten Michaël
Michael.Kalbermatten at ne.ch
Tue Jun 24 08:02:20 PDT 2014
Hi list,
I'm trying to render a road given a certain width in meters.
To achieve that, I did use SIZEUNITS METERS in the LAYER definition.
I'm using this layer via WMS in QGIS. At small scales (1:10'000), this is working great, the roads is well-sized regarding its real width, but as soon as I zoom in and have a larger scale then approximately 1:5'000, then this is not working anymore and the line width stays constant the more I zoom in.
I'm using MapServer 6.0.3. I did partially copy the mapfile content hereunder.
I think that I tried almost every possible parameter combination (like using MINSIZE, MAXSIZE, MINWIDTH, and so on), but nothing seems to work...
Did anyone ever encounter that issue ? Am I doing sometime wrong ?
Best regards
Michael
MAP
NAME "... "
DEFRESOLUTION 96
EXTENT 400000 100000 800000 300000
IMAGETYPE "png"
MAXSIZE 5120
RESOLUTION 96
STATUS ON
TRANSPARENT TRUE
UNITS METERS
LAYER
NAME "...."
TYPE LINE
METADATA
"wms_srs" "EPSG:21781"
"wms_title" "...."
END
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "...."
PROCESSING "CLOSE_CONNECTION=DEFER"
DATA "geom from .... using unique idobj using srid=21781"
TEMPLATE "foo"
PROJECTION
"init=epsg:21781"
END
CLASSITEM "objektart"
SIZEUNITS METERS
UNITS METERS
SYMBOLSCALEDENOM 1000
CLASS
NAME "Road"
EXPRESSION "Road"
STYLE
COLOR 255 0 0
WIDTH 40
END
END
END
END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140624/6f53b25c/attachment.html>
