[mapserver-users] SIZEUNITS set to meters
Håvard Tveite
havard.tveite at nmbu.no
Wed Jun 25 00:57:26 PDT 2014
I have not tested this for sizeunits meters, but for pixels
you need to set style MAXWIDTH (or MAXSIZE).
Håvard
On 2014-06-24 17:02, Kalbermatten Michaël wrote:
> Hi list,
> I'm trying to render a road given a certain width in meters.
> To achieve that, I did use SIZEUNITS METERS in the LAYER definition.
> I'm using this layer via WMS in QGIS. At small scales (1:10'000), this is working great, the roads is well-sized regarding its real width, but as soon as I zoom in and have a larger scale then approximately 1:5'000, then this is not working anymore and the line width stays constant the more I zoom in.
> I'm using MapServer 6.0.3. I did partially copy the mapfile content hereunder.
> I think that I tried almost every possible parameter combination (like using MINSIZE, MAXSIZE, MINWIDTH, and so on), but nothing seems to work…
> Did anyone ever encounter that issue ? Am I doing sometime wrong ?
> Best regards
> Michael
> MAP
> NAME "… "
> DEFRESOLUTION 96
> EXTENT 400000 100000 800000 300000
> IMAGETYPE "png"
> MAXSIZE 5120
> RESOLUTION 96
> STATUS ON
> TRANSPARENT TRUE
> UNITS METERS
> LAYER
> NAME "…."
> TYPE LINE
> METADATA
> "wms_srs" "EPSG:21781"
> "wms_title" "…."
> END
> STATUS ON
> CONNECTIONTYPE POSTGIS
> CONNECTION "…."
> PROCESSING "CLOSE_CONNECTION=DEFER"
> DATA "geom from …. using unique idobj using srid=21781"
> TEMPLATE "foo"
> PROJECTION
> "init=epsg:21781"
> END
> CLASSITEM "objektart"
> SIZEUNITS METERS
> UNITS METERS
> SYMBOLSCALEDENOM 1000
> CLASS
> NAME "Road"
> EXPRESSION "Road"
> STYLE
> COLOR 255 0 0
> WIDTH 40
> END
> END
> END
> END
> mapserver-users at lists.osgeo.org
Håvard Tveite
Department of Mathematical Sciences and Technology, NMBU
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.nmbu.no/imt/
