[mapserver-users] Valid extents for shape file, World Wind WMS Client
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Jun 25 07:00:48 PDT 2014
There was a .prj file in the zip archive you downloaded. That gives you the projection...
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of jonathanknez
Sent: Wednesday, June 25, 2014 8:05 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Valid extents for shape file, World Wind WMS Client
Steve,
*Your suggestions worked.* I am now able to use my MapServer to serve a shapefile to my World Wind client.
1. I changed the projection in my map file to 900913.
Initially I got a new error that, "msProcessProjection(): no options found in ‘init’ file". I checked my epsg file in /usr/share/proj/epsg. It did not contain a definition for 900913. I found a definition online. I added it to the end of my epsg file and it cleared up the error.
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
+y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs
2. Updated my wms_onlineresource field to replace that incorrect trailing ?
with a &.
Once those changes were made, it worked.
I have one follow on question, *how did you know that epsg:900913 should be used from looking at the shapefile?* Is there a dictionary somewhere that says Google Mercator=900913?
Here is my corrected map file per Steve's direction. Thank you for the help.
============= houston.map ==================== MAP
NAME houston
STATUS ON
SIZE 800 600
EXTENT -10720217.000000 3306038.000000 -10419354.000000 3606902.000000
UNITS METERS
SHAPEPATH "shapefiles/houston"
IMAGETYPE PNG24
PROJECTION
"init=epsg:900913"
END
WEB
METADATA
wms_title "Houston Title Web"
wms_enable_request "*"
wms_onlineresource
"http://10.0.0.141/cgi-bin/mapserver?map=/var/www/html/houston.map&"
wms_srs "epsg:900913 epsg:4326"
END
END
LAYER
NAME "Houston_Border"
DATA houston
STATUS ON
TYPE POLYGON
CLASS
STYLE
COLOR 246 241 223
OUTLINECOLOR 0 0 0
END
END
METADATA
wms_title "Houston Title Layer"
wms_extent "-10720217.000000 3306038.000000 -10419354.000000 3606902.000000"
END
PROJECTION
"init=epsg:900913"
END
END
END
View this message in context: http://osgeo-org.1560.x6.nabble.com/Valid-extents-for-shape-file-World-Wind-WMS-Client-tp5147433p5147873.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
