[mapserver-users] PostGIS Connection Failure
Humberto Cereser Ibanez
humberto at pastoraldacrianca.org.br
Wed Jun 25 07:18:02 PDT 2014
Hi Krishna,
On Tue, 2014-06-24 at 09:35 -0400, Krishna Priya Patury wrote:
> Just wanted to add, when I do a service iptables status, it is says
> Firewall is not running.
> On Tue, Jun 24, 2014 at 9:30 AM, Krishna Priya Patury
> <krishna.patury at gmail.com> wrote:
> Hi All,
> Any other ideas?
> The map server application installed outside of my Centos VM
> can connect to the Postgres database on the VM. I can also
> connect to the database both from within and outside the VM
> using psql.
> I believe the Mapserver installation on my VM is fine too as
> my shp2img and running the mapserver through command line work
> just fine. The issue is only when I try to connect to the
> database through the application from my VM.
> I do not see anything additional in the logs.
I think that the requisition from your application is not achieving your
VM.
Is the request sent by your application pass through a proxy that blocks
the 5432 port or there is a bridge over which the requests flow
directly?
> I can see that the database logs are not updated when I hit it
> though the application within the VM, understandably so with
> the error message in the browser.
> The only difference between running shp2img and the
> application is perhaps the user? I was able to open a
> succesful connection through psql as an 'apache' user as
> well(User which is running the Apache server). So am not sure
> what is missing.
> Thanks,
> Krishna.
Best regards,
> On Mon, Jun 23, 2014 at 5:24 PM, Krishna
> Yes I can connect to Postgres using the same
> connection information through psql both from within
> and outside my vm.
> Sent from my iPhone
> > On Jun 23, 2014, at 5:20 PM, Paul Ramsey
> <pramsey at cleverelephant.ca> wrote:
> > Did you restart your postgresql after making the
> changes to pg_hba and postgresql.conf? Can you telnet
> to port 5432? Can you connect with psql? Just ignore
> mapserver for now, you have a connection issue.
> > P.
> > http://postgis.net
> > http://cleverelephant.ca
> > On June 23, 2014 at 2:17:19 PM, Krishna
> (krishna.patury at gmail.com) wrote:
> >>> As I mentioned I have disabled the firewall. Or so
> I think. When
> >> I login as 'root' and click firewall it says
> disabled. Any way
> >> I can confirm/ test this?
> mapserver-users at lists.osgeo.org
