[mapserver-users] PostGIS Connection Failure
Krishna Priya Patury
krishna.patury at gmail.com
Wed Jun 25 08:13:25 PDT 2014
Thanks for responding. Would you please tell me how to check that? When I
go to Network Proxy on the VM, "Direct Connection to internet" is selected.
Both Mapserver and Postgres on the same VM. Do you think something might
still be blocking the port? I am able to open a psql connection just fine
using the same port. What is even more confusing is a Mapserver application
outside the VM is able to connect to the Database on the VM just fine.
On Wed, Jun 25, 2014 at 10:18 AM, Humberto Cereser Ibanez <
humberto at pastoraldacrianca.org.br> wrote:
> Hi Krishna,
> On Tue, 2014-06-24 at 09:35 -0400, Krishna Priya Patury wrote:
> > Just wanted to add, when I do a service iptables status, it is says
> > Firewall is not running.
> > On Tue, Jun 24, 2014 at 9:30 AM, Krishna Priya Patury
> > <krishna.patury at gmail.com> wrote:
> > Hi All,
> > Any other ideas?
> > The map server application installed outside of my Centos VM
> > can connect to the Postgres database on the VM. I can also
> > connect to the database both from within and outside the VM
> > using psql.
> > I believe the Mapserver installation on my VM is fine too as
> > my shp2img and running the mapserver through command line work
> > just fine. The issue is only when I try to connect to the
> > database through the application from my VM.
> > I do not see anything additional in the logs.
> I think that the requisition from your application is not achieving your
> VM.
> Is the request sent by your application pass through a proxy that blocks
> the 5432 port or there is a bridge over which the requests flow
> directly?
> > I can see that the database logs are not updated when I hit it
> > though the application within the VM, understandably so with
> > the error message in the browser.
> > The only difference between running shp2img and the
> > application is perhaps the user? I was able to open a
> > succesful connection through psql as an 'apache' user as
> > well(User which is running the Apache server). So am not sure
> > what is missing.
> > Thanks,
> > Krishna.
> Best regards,
> > On Mon, Jun 23, 2014 at 5:24 PM, Krishna
> > Yes I can connect to Postgres using the same
> > connection information through psql both from within
> > and outside my vm.
> > Sent from my iPhone
> > > On Jun 23, 2014, at 5:20 PM, Paul Ramsey
> > <pramsey at cleverelephant.ca> wrote:
> > > Did you restart your postgresql after making the
> > changes to pg_hba and postgresql.conf? Can you telnet
> > to port 5432? Can you connect with psql? Just ignore
> > mapserver for now, you have a connection issue.
> > > P.
> > > http://postgis.net
> > > http://cleverelephant.ca
> > > On June 23, 2014 at 2:17:19 PM, Krishna
> > (krishna.patury at gmail.com) wrote:
> > >>> As I mentioned I have disabled the firewall. Or so
> > I think. When
> > >> I login as 'root' and click firewall it says
> > disabled. Any way
> > >> I can confirm/ test this?
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140625/3ccb4719/attachment.html>
