[mapserver-users] PostGIS Connection Failure
Carlos Ruiz
boolean10001 at yahoo.com
Thu Jun 26 08:03:28 PDT 2014
Hi Krishna,
On Wed, 6/25/14, Krishna Priya Patury <krishna.patury at gmail.com> wrote:
> Subject: Re: [mapserver-users] PostGIS Connection Failure
> To: humberto at pastoraldacrianca.org.br
> Cc: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
> Date: Wednesday, June 25, 2014, 10:13 AM
> Thanks for responding. Would you please tell
> me how to check that? When I go to Network Proxy on the VM,
> "Direct Connection to internet" is selected.
> Both Mapserver and Postgres on the
> same VM. Do you think something might still be blocking the
> port? I am able to open a psql connection just fine using
> the same port. What is even more confusing is a Mapserver
> application outside the VM is able to connect to the
> Database on the VM just fine.
This is really weird. Are you sure the application outside of your VM that works has the same connection string as the one that doesn't works ? Both applications (the one that works and the one that doesn´t) are using the same version of Mapserver ? Both applications (the one that works and the one that doesn´t) are hosted in the same machine/VM ?
Mtro. Carlos Ruiz
