[mapserver-users] Map data strategy
Malm Paul
paul.malm at saabgroup.com
Thu Jun 26 23:47:48 PDT 2014
Thanks everyone for the response!
Will Tile index indexing increase the performance if we already are using extent on layers?
/Paul
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at cleverelephant.ca]
Sent: den 25 juni 2014 22:02
To: Malm Paul
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Map data strategy
If you're using a map file with 100s of layers, you really must set an EXTENT on each layer to mapserver can intelligently ignore layers that are not "in scope" for the current view.
P
On Tue, Jun 24, 2014 at 10:36 PM, Malm Paul <paul.malm at saabgroup.com> wrote:
> Hi,
> I’ve just started using Mapserver and have a question, that could help
> me to cut corners.
> 1) I have a lot of S57 charts in different scale groups 1-6.
> 2) It should be simple to maintain the map data (a lot of upgrades).
> 3) Of course, it should be fast.
> Strategy of today:
> I have the original data stored in the original format on ram disk. I
> have one map file that INCLUDEs all “layer” files (one per chart).
> The layer files defines the all the interesting chart features
> (layers) and the max scale.
> I was thinking that I only shall use max scale, not min scale, because
> if I don’t have a chart with a larger scale a certain position when I
> zoom in, then I shall at least see a chart. Even if has a to small
> scale for this zoom. I don’t have any spatial restrictions on each
> layer or layer file, just for the map file -90, -180, 90, 180 (i.e no
> limits)
> Is it possible to have spatial limitations on a layer?
> When I use this strategy the map server chokes then I zoom in too much.
> I can see that the map configuration could be done in a lot of
> different ways,
> How would your strategy be?
> Kind regards,
> Paul
