[mapserver-users] color attribute question
Do Wi
dowi84 at gmail.com
Thu Jun 26 08:29:27 PDT 2014
hi, thanks allot!
that is exactly what i did after another user suggested it ( Cristiano
Sumariva ).
here it is for reference:
CREATE OR REPLACE FUNCTION temp.ms_colorMath( percentile double precision )
RETURNS varchar
LANGUAGE plpgsql
AS
DECLARE
C double precision;
X double precision;
m double precision;
H int;
V double precision;
S double precision;
R int;
G int;
B int;
BEGIN
--see here http://www.rapidtables.com/convert/color/hsv-to-rgb.htm
--if H != 0 need to change the function
--curently - red gradient
S := percentile;
IF (S < 0.1 AND S > 0) THEN S := 0.1; END IF;
H := 0;
V := 1.0;
C := V * S;
X := C * (1-abs(mod(H/60,2)-1));
m := V-C;
R := ((C + m)*255 )::int;
G := ((X + m)*255 )::int;
B := ((0 + m)*255 )::int;
RETURN (R)::text || ' ' || (G)::text || ' ' || (B)::text;
END
On Thu, Jun 26, 2014 at 6:24 PM, Carlos Ruiz <boolean10001 at yahoo.com> wrote:
> To achieve more flexibility as you want, you have to code a function with
> PL/pgSQL in PostgreSQL or with PHP/Python/Java/C# with Mapscript to define
> which is the base color (red, green, blue, yellow ...) and then to
> calculate the percent in the right RGB channel.
> Cheers
> Mtro. Carlos Ruiz
> On Mon, 6/23/14, Do Wi <dowi84 at gmail.com> wrote:
> Subject: Re: [mapserver-users] color attribute question
> To: "Carlos Ruiz" <boolean10001 at yahoo.com>
> Date: Monday, June 23, 2014, 2:56 PM
> thanks allot!
> Steve and another user here mentioned this path
> and it did work!only problem is that it cannot be
> changed later if for example the user chooses a blue
> gradient.
> how will i go about doing it with
> mapscript?
> maybe it relates to my question herehttp://
> gis.stackexchange.com/questions/102862/when-to-choose-mapscript-over-mapfile-or-vice-versa
> thanks allot!dovi
> On Mon, Jun 23, 2014
> at 6:13 PM, Carlos Ruiz <boolean10001 at yahoo.com>
> wrote:
> Do,
> If
> you want to do this without using mapscript, you can pull
> the gradient calculation as an attribute from your data
> table.
> ALTER TABLE mytable ADD COLUMN gradient_color
> VARCHAR;
> UPTATE mytable SET gradient_color = floor(gradient *
> 255)::text || ' 0 0';
> Cheers
> Mtro. Carlos Ruiz
> On Monday, June 23, 2014 4:59 PM, "Lime, Steve D
> (MNIT)" <Steve.Lime at state.mn.us>
> wrote:
> You can compute a color
> string using PostgreSQL string functions:
> SELECT percentage ||
> ‘ 0 0’ AS color FROM …
> Steve
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org]
> On Behalf Of Do Wi
> Sent: Sunday, June 22, 2014 3:50 PM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] color attribute
> question
> hi!
> i have this
> scenario:
> i have a column in my
> postgis table which contains a double representing a
> percentage.
> i want to color my
> polygons in a gradient fashion based on that
> number.
> the docs states three
> ways to specify color:
> 1. three [1-255]
> numbers
> 2. hex
> string
> 3.
> [attribute]
> but the attribute must
> be a string by itself in the same format as options 1 or
> 2.
> how can i achieve
> something like
> COLOR [percentage]*255 0
> 0
> or
> COLOR [percentage] 0
> 0
> if percentageis already
> 0..255
> for a red gradient for
> example?
> thanks
> allot!
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140626/91d6697e/attachment.html>
