[mapserver-users] Mapcache on Windows with IIS - any binaries available?
Mark Volz
MarkVolz at co.lyon.mn.us
Thu Jun 26 13:19:57 PDT 2014
Henrik,
Someone can correct me if I am wrong, but It is my understanding that mapcache will only work with apache. It is possible to run IIS and MS4W (apache) on the same machine. I have IIS is set up to listen to one IP address, and MS4W is set up to listen to another ip address. That being said I do not know if this is the cleanest install. In addition, The version of MS4W (3.0.4 dev) that has mapcache is over two years old. I hope a new version of MS4W will come out sometime soon!
Sincerely,
Mark Volz, GISP
> Hi,
> I am trying to setup a mapserver+mapcache installation on Windows 2012,
> using IIS as the webserver.
> (The powers that be insist on trying it on Windows before doing it on Linux?)
> I?ve found the mapserver binaries on http://www.gisinternals.com/sdk/,
> and have mapserver working in FastCGI mode on IIS. So I?d like to add
> mapcache to the software stack, but it isn?t included in the gisinternals.com
> package. I have seen Paul James? message that building and running it is
> possible http://lists.osgeo.org/pipermail/mapserver-users/2013-
> March/074294.html - but I don?t have Visual C available.
> So I guess what I am really asking for is: Is there a precompiled binary of
> mapcache for Windows x64 available anywhere?
> Thanks in advance.
