[mapserver-users] Installing MapServer on Windows
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
james.evans.4 at us.af.mil
Fri Jun 27 16:10:06 PDT 2014
Can you post the map file?
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of Kris Spring [kris.spring at omnyon.com]
Sent: Friday, June 27, 2014 3:11 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Installing MapServer on Windows
Howdy,
I've got a dump of a NASA World Wind map database and I'm trying to setup a standalone map environment. Not sure if anyone has done this before, but the documentation isn't exactly up to date or complete.
Here's my setup:
Windows 7 64-bit
MapServer 6.4.1
I've installed MapServer and have modified IIS7 so that I can run mapserv.exe. The NASA World Wind comes with a .map file and basically everything that I need. When I try to bring up the .map file I get the following error:
Sample url: localhost/mapserver/mapserv.exe?map=<path>/nasaww.map&request=getacpabilities&service=wms
msProcessProjection(): Projection library error. proj error "Permission denied" for "init=epsg:4326"
I've tried looking at permissions and opening everything up just to see if I can get it to work, but no dice. Anyone have any ideas?
Thanks,
Kris
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140627/877bb3f8/attachment-0001.html>
