[mapserver-users] Mapcache on Windows with IIS - any binaries available?
Størner.Henrik Juul HSO
HSO at kmd.dk
Mon Jun 30 03:26:01 PDT 2014
Hi Michal,
Michael Kleih wrote:
> No, I am running both Mapserver and Mapcache with IIS.
I assume you compiled it yourself?
I am working on that, since I got my hands on a Visual C compiler. If you have any tips on how to do it, I would like to hear about it. Right now I have the dependencies compiled (apr, fastcgi, pcre, sqlite, cmake, libcurl, libjpeg, libpng, zlib) so I am getting there. Just need to persuade the mapcache cmake file that I have all of the libraries installed ...
Thanks,
Henrik
On 27.06.2014 09:57, Størner.Henrik Juul HSO wrote:
> Hi,
> Mark Volz wrote:
>> Someone can correct me if I am wrong, but It is my understanding that
>> mapcache will only work with apache.
> My understanding is that mapcache can run either as an Apache module,
> or as a (Fast)CGI application - see
> http://mapserver.org/mapcache/install.html#cgi-fastcgi-specific-instru
> ctions
> I am pursuing the CGI method due to some external desires for sticking with a 'pure' Windows+IIS solution, but if that is not possible then I totally agree that Apache is the way to go.
> Regards,
> Henrik
Vi gør opmærksom på, at denne e-mail kan indeholde fortrolig information. Hvis du ved en fejltagelse modtager e-mailen, beder vi dig venligst informere afsender om fejlen ved at bruge svarfunktionen. Samtidig beder vi dig slette e-mailen i dit system uden at videresende eller kopiere den. Selvom e-mailen og ethvert vedhæftet bilag efter vores overbevisning er fri for virus og andre fejl, som kan påvirke computeren eller it-systemet, hvori den modtages og læses, åbnes den på modtagerens eget ansvar. Vi påtager os ikke noget ansvar for tab og skade, som er opstået i forbindelse med at modtage og bruge e-mailen.
Please note that this message may contain confidential information. If you have received this message by mistake, please inform the sender of the mistake by sending a reply, then delete the message from your system without making, distributing or retaining any copies of it. Although we believe that the message and any attachments are free from viruses and other errors that might affect the computer or it-system where it is received and read, the recipient opens the message at his or her own risk. We assume no responsibility for any loss or damage arising from the receipt or use of this message.
