[mapserver-users] large # of GeoTiffs mapfile/index strategy
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Fri Jun 27 13:01:37 PDT 2014
Use gdaltindex with -t_srs http://www.gdal.org/gdaltindex.html and all your troubles are solved.
Jukka Rahkonen
Lähettäjä: Mark Korver<mailto:mwkorver at gmail.com>
Lähetetty: 27.6.2014 21:57
Vastaanottaja: mapserver-users<mailto:mapserver-users at lists.osgeo.org>
Aihe: [mapserver-users] large # of GeoTiffs mapfile/index strategy
Hi Experts,
I need a little advice on how to do lots of aerial image GeoTiffs quickly. I have a large region with many GeoTiffs covering 9 UTM zones. Typically I would put together a map file with layers per utm zone and use shapefile index to point at the GeoTiffs. I know that declaring the extent per layer is important when you have a lot of layers. The GeoTiffs are RGB, internally tiled, and jpeg compressed. They are also about 20-30MB in size.
My question is, has anyone done any testing between doing this via shapefile index vs GDAL .vrt files? Which would perform faster?
My current setup is using Mapserver behind nginx in fastcgi mode.
Thanks for any help on this.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140627/fb4f3ad8/attachment.html>
