[mapserver-users] TinyOWS: Axis order fix wanted
Olivier Courtin
olivier.courtin at gmail.com
Mon Jun 30 15:33:18 PDT 2014
On Sat, Jun 28, 2014 at 11:38 PM, Even Rouault
<even.rouault at mines-paris.org> wrote:
> The following pull request should fix Jukka's issue :
> https://github.com/mapserver/tinyows/pull/65
I've just commited the pull request.
Thanks for this one Even,
Jukka could you check on your own that everything is fine for you ?
Olivier
