[mapserver-users] Color temperature control (night-time viewing of maps)
Norman Vine
nhv at cape.com
Mon Mar 3 09:09:51 PST 2014
Bob
We started with the Standard NOAA chart palette foray then used a gamma
function to tone this down for Dawn/Dusk but used a special night time palette
based on user feedback note that at sea there is usually a 'blackout environment'
which is much darker then most
Have you seen this project ?
http://jonls.dk/redshift/
Norman
On Mar 3, 2014, at 11:49 AM, "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us> wrote:
> Hi Norman,
> I had another thought after I sent the first post. Maybe something along the lines of an inside/outside view switcher. The outside mode would self correct based on the location/time settings. I’m really interested in this automated approach to making the settings change. I have even worked out how I can make the changes to a mapfile could work from a config file. I just need the actual RGB conversion routine to try out the idea. Optimum settings for those three values you described would get things started, then I would need to figure out the best approach to apply by location/time, (heck, you could even factor in weather conditions down the line . . .)
> bobb
> From: Norman Vine [mailto:nhv at cape.com]
> Sent: Monday, March 03, 2014 10:40 AM
> To: Basques, Bob (CI-StPaul)
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Color temperature control (night-time viewing of maps)
> Bob
> Back in the day when I was working on marine navigation chart displays
> we used separate color tables for different light conditions
> we found that 3 tables sufficed, Day, Dusk/Dawn, Night
> we cheated a bit and used 64 bit palettes this way with a little trickery
> we could pack everything into a normal 8 bit color table
> In practice this worked quite well
> HTH
> Norman
> On Mar 3, 2014, at 11:30 AM, "Basques, Bob (CI-StPaul)" <bob.basques at ci.stpaul.mn.us> wrote:
> All,
> So, I’ve been reading up on nighttime colors for electronic display(s). I was wondering if anyone has any pointers on information about applying color temperature corrections to displays for nighttime viewing. I’m in need of providing this functionality to some night crew workers.
> My first thought was to apply some sort of RGB algorithm to the mapfile color settings. Then I thought maybe a middleware processor routine (between MapServer and the browser) might be a better approach, or possibly using something in the browser . . .
> I’m only looking at setting up distinct color settings at the moment. Maybe 3-5 ranges to start with. I do know that some Mac hardware has some display monitoring for color temperature. I would prefer to do something that could apply globally however.
> Maybe there are Browser functions that can be applied to the problem (I haven’t found anything specific there yet though.
> Thanks
> Bobb
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140303/f590c321/attachment.html>
