[mapserver-users] Need help with RFC109: Refactor Runtime Substitution
Andrea Peri
aperi2007 at gmail.com
Sat Mar 8 07:08:31 PST 2014
Hi, I'm try to check if the new RFC109 is compatible with my mapfile.
I try a fast check and seem that my mapfile dont work with RFC109.
But reading the documentation I don't understand why it don't work.
The only substitutions I have are in the CLASS section:
(the db is a spatialite accessed by OGR)
LAYER
CONNECTIONTYPE OGR
CONNECTION "/path-to-spatialite-db/db.sqlite"
DATA "TABLE1"
VALIDATION
'code' '.*'
'default_code' ''
END
CLASSITEM "THE_CODE"
CLASS
NAME '...'
EXPRESSION ('[the_code]' ne '%code%')
CLASS
NAME '.....'
EXPRESSION ('[the_code]' eq '%code%')
I read that the only incompatible should be inside the metadata section,
AFAIK this is not the case.
So I guess the substitution in the CLASS section should work .
But my test don't work.
I don't understand if this is a bug or a my mis-understaind of the new
RFC109.
Thx,
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140308/5bac387d/attachment.html>
