[mapserver-users] Need help with RFC109: Refactor Runtime Substitution
Thomas Bonfort
thomas.bonfort at gmail.com
Sat Mar 8 07:16:47 PST 2014
Andrea,
it's a bug, I've just pushed a fix.
thanks for reporting!
thomas
On 08/03/2014 16:08, Andrea Peri wrote:
> Hi, I'm try to check if the new RFC109 is compatible with my mapfile.
> I try a fast check and seem that my mapfile dont work with RFC109.
> But reading the documentation I don't understand why it don't work.
> The only substitutions I have are in the CLASS section:
> (the db is a spatialite accessed by OGR)
> LAYER
> CONNECTIONTYPE OGR
> CONNECTION "/path-to-spatialite-db/db.sqlite"
> DATA "TABLE1"
> VALIDATION
> 'code' '.*'
> 'default_code' ''
> END
> CLASSITEM "THE_CODE"
> CLASS
> NAME '...'
> EXPRESSION ('[the_code]' ne '%code%')
> CLASS
> NAME '.....'
> EXPRESSION ('[the_code]' eq '%code%')
> I read that the only incompatible should be inside the metadata section,
> AFAIK this is not the case.
> So I guess the substitution in the CLASS section should work .
> But my test don't work.
> I don't understand if this is a bug or a my mis-understaind of the new
> RFC109.
> Thx,
> mapserver-users at lists.osgeo.org
