[mapserver-users] JSON template
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Mar 12 08:27:06 PDT 2014
That's the appropriate work around at this point. Typically I'll put a few things that I know will always be present at the end. For example the if the query is triggered by a point query I prepend the x/y:
'point':{
'epsg:26915': [[mapx], [mapy]],
'epsg:4326': [[maplon], [maplat]]
I also tend to use the nodtata attribute of the resultset tag to output a null value for the object if it wasn't found. That way each layer would *always* be represented in the output. Our devs preferred checking for a null as opposed to checking if a property exists. Not sure what the proper convention is but it seems to work for us at the expense of slightly larger responses. Here's an example from our service we have:
[resultset layer="ama" nodata=" 'ama':null,"][feature]
'ama':{
'name':'[item name="unit_name"]',
'id':'[item name="uniqueid" lc="true"]'
},[/feature][/resultset]
[resultset layer="sna" nodata=" 'sna':null,"][feature]
'sna':{
'name':'[item name="site_name"]',
'id':'[item name="bremcode" lc="true"]',
'url':'http://www.dnr.state.mn.us/snas/detail.html?id=[item name="bremcode" lc=true]'
If the ama and sna layers return no results you'd see:
'sna':null,
'ama':null,
in the JSON response.
Oh, I believe any attribute in a template tag must use no quotes or double quotes, same goes for HTML legend templates since they use the same tag parser.
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Richard Greenwood
Sent: Tuesday, March 11, 2014 7:03 PM
To: mapserver
Subject: [mapserver-users] JSON template
The JSON template has [feature trimlast=","] for a single layer that may return multiple records, but I don't see that functionality for the whole JSON object. For example if I have two layers but only one returns results I end up with a trailing comma and invalid JSON.
// MapServer template
[resultset layer=layer1]
[/feature]
}, // might need to trim this comma if layer below doesn't return result
[/resultset]
[resultset layer=layer2]
[/feature]
} // no comma here because we think it's last result object
[/resultset]
I can work around it by putting a comma and empty object at the end:
which is the way I've done it when writing JSON with standard templates, but that's sort of inconsistent with the [feature trimlast=","] option.
Am I missing anything? Should I file a feature enhancement request?
And trimlast="," does seem to need to require double, not single quotes.
Thanks,
Rich
Richard Greenwood
richard.greenwood at gmail.com<mailto:richard.greenwood at gmail.com>
www.greenwoodmap.com<http://www.greenwoodmap.com>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140312/784c319e/attachment-0001.html>
