[mapserver-users] Layer with point from X and Y columns in
Jakub Štambachr
stambikk at gmail.com
Thu Mar 13 03:39:04 PDT 2014
I have table in Oracle Database that contains points specified by columns X
and Y (The table also contains SDO_Geometry column but it's not always
filled with data and I'm not at liberty to modify the table).
My question is: Is it possible to specify layers with point using the
columns X and Y?
So far I have something like this and I need an alternative to replace the
DATA
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION "isypoo/password at orcl"
DATA "shape FROM (select table.shape as SHAPE from table)"
I tried the following:
DATA "shape FROM (select MDSYS.SDO_GEOMETRY(2001, NULL,
MDSYS.SDO_POINT_TYPE(table.x, table.Y, NULL), NULL, NULL) AS shape from
table)"
But got the following error:
msDrawMap(): Image handling error. Failed to draw layer named 'mosty'.
msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error: ORA-13226:
interface not supported without a spatial index
Is there any other way of doing this without modifying the database?
Thank you for your help,
Jakub
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140313/8173c509/attachment.html>
