[mapserver-users] join shp with csv
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Thu Mar 13 06:39:37 PDT 2014
I have had no time to look at your files but I see that ogrinfo reports osm_id as a string. Write .csvt file http://www.gdal.org/ogr/drv_csv.html for converting it to integer, perhaps join requires same data types.
-Jukka Rahkonen-
Jörg Thomsen wrote:
> Hello Jeff,
> yes, this looks better.
> > $ ogrinfo ./shapes_join/join.csv join -summary
> > INFO: Open of `./shapes_join/join.csv'
> > using driver `CSV' successful.
> > Layer name: join
> > Geometry: None
> > Feature Count: 208
> > Layer SRS WKT:
> > (unknown)
> > osm_id: String (0.0)
> > name_join: String (0.0)
> but the join in mapserver still doesn't work.
> Jörg
> Am 13.03.2014 13:39, schrieb Jeff McKenna:
> > On 2014-03-13, 9:36 AM, Jeff McKenna wrote:
> >> On 2014-03-13, 7:07 AM, Jörg Thomsen wrote:
> >>> $ ogrinfo join.csv lookup -summary
> >>> INFO: Open of `join.csv'
> >>> FAILURE: Couldn't fetch requested layer lookup!
> >>> This is my only hint but unfortunatly I don't know what ogr wants to
> >>> tell me.
> >> You seem to be following my examples very closely from
> >> http://www.mapserver.org/mapfile/join.html#example-3-join-from-shape-
> >> dataset-to-csv-file which is good, but be careful, "lookup" in my
> >> example is the OGR layername; in your case it will be different. You
> >> should just try "ogrinfo join.csv" to get a list of available layers
> >> through OGR. See some examples of that in action:
> >> http://mapserver.org/input/vector/ogr.html#how-to-use-ogrinfo
> > Ah but I almost forgot the most important switch for layernames:
> > ""ogrinfo join.csv -summary"
> > Good luck there!
> > -jeff
> mapserver-users at lists.osgeo.org
