[mapserver-users] join shp with csv
Jörg Thomsen
jt at mapmedia.de
Thu Mar 13 07:09:04 PDT 2014
Am 13.03.2014 14:39, schrieb Rahkonen Jukka (Tike):
> Hi,
> I have had no time to look at your files but I see that ogrinfo reports osm_id as a string. Write .csvt file http://www.gdal.org/ogr/drv_csv.html for converting it to integer, perhaps join requires same data types.
good idea, thanks.
But doesn't help.
I have updated the online files, perhaps you'll have some time within
the next few days.
Jörg
> -Jukka Rahkonen-
> Jörg Thomsen wrote:
>> Hello Jeff,
>> yes, this looks better.
>>> $ ogrinfo ./shapes_join/join.csv join -summary
>>> INFO: Open of `./shapes_join/join.csv'
>>> using driver `CSV' successful.
>>> Layer name: join
>>> Geometry: None
>>> Feature Count: 208
>>> Layer SRS WKT:
>>> (unknown)
>>> osm_id: String (0.0)
>>> name_join: String (0.0)
>> but the join in mapserver still doesn't work.
>> Jörg
>> Am 13.03.2014 13:39, schrieb Jeff McKenna:
>>> On 2014-03-13, 9:36 AM, Jeff McKenna wrote:
>>>> On 2014-03-13, 7:07 AM, Jörg Thomsen wrote:
>>>>> $ ogrinfo join.csv lookup -summary
>>>>> INFO: Open of `join.csv'
>>>>> FAILURE: Couldn't fetch requested layer lookup!
>>>>> This is my only hint but unfortunatly I don't know what ogr wants to
>>>>> tell me.
>>>> You seem to be following my examples very closely from
>>>> http://www.mapserver.org/mapfile/join.html#example-3-join-from-shape-
>>>> dataset-to-csv-file which is good, but be careful, "lookup" in my
>>>> example is the OGR layername; in your case it will be different. You
>>>> should just try "ogrinfo join.csv" to get a list of available layers
>>>> through OGR. See some examples of that in action:
>>>> http://mapserver.org/input/vector/ogr.html#how-to-use-ogrinfo
>>> Ah but I almost forgot the most important switch for layernames:
>>> ""ogrinfo join.csv -summary"
>>> Good luck there!
>>> -jeff
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
