[mapserver-users] join shp with csv
Brent Fraser
bfraser at geoanalytic.com
Thu Mar 13 08:59:17 PDT 2014
Jörg,
According to the JOIN doc (mapserver.org/mapfile/join.html) on CSV, your
template should use
name_join: [test_2]</br>
where [test_2] is a concatenation of your JOIN NAME ("test") and the
column id (2) in the CSV file.
Best Regards,
Brent Fraser
On 3/13/2014 8:09 AM, Jörg Thomsen wrote:
> Am 13.03.2014 14:39, schrieb Rahkonen Jukka (Tike):
>> Hi,
>> I have had no time to look at your files but I see that ogrinfo reports osm_id as a string. Write .csvt file http://www.gdal.org/ogr/drv_csv.html for converting it to integer, perhaps join requires same data types.
> good idea, thanks.
> But doesn't help.
> I have updated the online files, perhaps you'll have some time within
> the next few days.
> Jörg
>> -Jukka Rahkonen-
>> Jörg Thomsen wrote:
>>> Hello Jeff,
>>> yes, this looks better.
>>>> $ ogrinfo ./shapes_join/join.csv join -summary
>>>> INFO: Open of `./shapes_join/join.csv'
>>>> using driver `CSV' successful.
>>>> Layer name: join
>>>> Geometry: None
>>>> Feature Count: 208
>>>> Layer SRS WKT:
>>>> (unknown)
>>>> osm_id: String (0.0)
>>>> name_join: String (0.0)
>>> but the join in mapserver still doesn't work.
>>> Jörg
>>> Am 13.03.2014 13:39, schrieb Jeff McKenna:
>>>> On 2014-03-13, 9:36 AM, Jeff McKenna wrote:
>>>>> On 2014-03-13, 7:07 AM, Jörg Thomsen wrote:
>>>>>> $ ogrinfo join.csv lookup -summary
>>>>>> INFO: Open of `join.csv'
>>>>>> FAILURE: Couldn't fetch requested layer lookup!
>>>>>> This is my only hint but unfortunatly I don't know what ogr wants to
>>>>>> tell me.
>>>>> You seem to be following my examples very closely from
>>>>> http://www.mapserver.org/mapfile/join.html#example-3-join-from-shape-
>>>>> dataset-to-csv-file which is good, but be careful, "lookup" in my
>>>>> example is the OGR layername; in your case it will be different. You
>>>>> should just try "ogrinfo join.csv" to get a list of available layers
>>>>> through OGR. See some examples of that in action:
>>>>> http://mapserver.org/input/vector/ogr.html#how-to-use-ogrinfo
>>>> Ah but I almost forgot the most important switch for layernames:
>>>> ""ogrinfo join.csv -summary"
>>>> Good luck there!
>>>> -jeff
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
