[mapserver-users] Migrating from MS4W to GISInternals
Tamas Szekeres
szekerest at gmail.com
Sun Mar 16 05:52:30 PDT 2014
I suspect hdf5.dll and hdf5_hl.dll is still missing on your target
directory. Copy those files from the .zip package mentioned before.
Tamas
2014-03-16 12:59 GMT+01:00 EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE <
james.evans.4 at us.af.mil>:
> Hi Tamas,
> I changed the PROJ_LIB to the correct directory, and that fixed that
> problem. Now I'm having trouble getting some of the gdal dlls to run.
> I've tried several raster sets, including Natural Earth, and Blue Marble,
> and I get the errors below. These errors also appear at the top of the
> GetCapabilities document. I was able to get a vector set (Natural Earth
> State Boundaries) to return a proper image so at least that's some
> progress. Any suggestions on getting this working would be appreciated.
> Thanks,
> James
> ERROR 1: Can't load requested DLL: C:\Program Files\MapServer\gdalplugins\gdal_BAG.dll
> 126: The specified module could not be found.
> ERROR 1: Can't load requested DLL: C:\Program Files\MapServer\gdalplugins\gdal_GMT.dll
> ERROR 1: Can't load requested DLL: C:\Program Files\MapServer\gdalplugins\gdal_HDF5.dll
> ERROR 1: Can't load requested DLL: C:\Program Files\MapServer\gdalplugins\gdal_HDF5Image.dll
> ERROR 1: Can't load requested DLL: C:\Program Files\MapServer\gdalplugins\gdal_netCDF.dll
> *From:* Tamas Szekeres [szekerest at gmail.com]
> *Sent:* Sunday, March 16, 2014 2:28 AM
> *To:* EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Migrating from MS4W to GISInternals
> You should probably set CONFIG PROJ_LIB to a valid directory (in the
> map file) containing the projection support files.
> Tamas
> 2014-03-16 0:30 GMT+01:00 EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE <
>> Good deal. I had to enable cgi extensions under IIS. Anyway, now I'm
>> having trouble with my map file. I get this error:
>> *msProcessProjection(): Projection library error. proj error
>> "Permission denied" for "init=epsg:4326"*
>> Here's my map file. I'm just trying to get Natural Earth working to
>> begin with. Why wouldn't this version recognize 4326? If I take out the
>> init statement, I get an error saying I have to have a projection at the
>> top level.
>> Thanks,
>> James
>> MAP
>> NAME "RADESWMS"
>> EXTENT -180 -90 180 90
>> SIZE 512 512
>> UNITS DD
>> IMAGECOLOR 0 0 0
>> #CONFIG PROJ_LIB "/ms4w/proj/nad/"
>> WEB
>> #IMAGEPATH "/ms4w/tmp/ms_tmp/"
>> #TEMPLATE "/ms4w/Apache/htdocs/dummy_template.html"
>> METADATA
>> "wms_title" "RADES_WMS"
>> "wms_name" "84RADES_WMS"
>> #"wms_onlineresource" "
>> http://localhost/cgi-bin/radeswms.exe?SERVICE=WMS"
>> "wms_srs" "EPSG:4326"
>> "wms_extent" "-180 -90 180 90"
>> "Wms_enable_request" "*"
>> END
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> LAYER
>> NAME "NaturalEarth"
>> METADATA
>> "wms_title" "NaturalEarth"
>> "wms_name" "NaturalEarth"
>> "wms_srs" "ESPG:4326"
>> "wms_style" "Default"
>> END
>> STATUS ON
>> TYPE RASTER
>> TILEINDEX "d:\\MapData\\NaturalEarthCrossBlend\\NaturalEarth"
>> TILEITEM "LOCATION"
>> #PROJECTION
>> # "init=epsg:4326"
>> #END
>> End
>> END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140316/aeb993e1/attachment-0001.html>
