[mapserver-users] Processing JP2000 files
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Thu Mar 20 06:44:45 PDT 2014
Are your JPEG2000 images the same? SOT marker is JPEG2000 stuff and it means "start of tilepart". If images are the same then the message means that something has changed in GDAL part. GDAL has several JPEG200 drivers and they all behave in a bit different way. Check which driver you have in your old system and which one you have now with "gdalinfo --formats".
I warn that from the free alternatives only OpenJPEG driver is something that can be considered for real use.
-Jukka Rahkonen-
James_in_Utah wrote:
> There must have been something wrong with my shapefile, because I tried this
> at home and I was able to get the same data to work. Now the problem is that
> the image I see on my client is all washed out, not a variant RGB image but
> mostly brownish with weak greens. None of the reds or blues are making it
> through. Plus, where the tiles overlap I can see the edges are blended from the
> overlapping tiles. This wasn't the case with the older GDAL from MS4W. Has
> something changed? Is there some directive in the layer that I'm missing?
> Thanks,
> James
> View this message in context: http://osgeo-
> org.1560.x6.nabble.com/Processing-JP2000-files-tp5129997p5130136.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
