[mapserver-users] Combine GetFeatureInfo for layers with same data source
TDS
tds at tds-net.de
Thu Mar 27 03:57:53 PDT 2014
Hello,
I've read this and I'm confused of how it can work...
ONE-TO-ONE or ONE-TO-MANY or ... I want to have a solution *scream* If
both layers are queried it should be one table, because the date is the
same. Only the class item differs.
Example Mapfile:
LAYER
STATUS on
NAME "Trinkwasserversorgung"
TYPE POLYGON
DATA "wv_wilster_84.shp"
DUMP true
TOLERANCE 3
TOLERANCEUNITS pixels
CLASSITEM "TW"
HEADER "templates/header.html"
TEMPLATE "templates/template.html"
FOOTER "templates/footer.html"
JOIN
NAME "Wasser"
TABLE "wv_wilster_84.dbf"
FROM "Id"
TO "Id"
TYPE ONE-TO-ONE
END
CLASS
NAME "Trinkwasser"
EXPRESSION "Trinkwasser"
STYLE
COLOR 130 192 255
END
STYLE
OUTLINECOLOR 120 120 120
WIDTH 2
ANTIALIAS TRUE
END
END
CLASS
NAME "Selbstversorger"
STYLE
SYMBOL "im_schraffur"
END
EXPRESSION "Selbstversorger"
STYLE
WIDTH 2
ANTIALIAS TRUE
END
END
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_title" "Verbandsgebiet"
"wms_title metadata" ""
"wms_include_items" "all"
"wms_srs" "EPSG:4326 EPSG:54004 EPSG:41001
EPSG:31467 EPSG:31468"
END
END
LAYER
STATUS on
NAME "Abwasserentsorgung"
TYPE POLYGON
DUMP true
TOLERANCE 3
CLASSITEM "AW"
JOIN
NAME "Wasser"
FROM "Id"
TO "Id"
TYPE ONE-TO-ONE
END
CLASS
NAME "Abwasser"
EXPRESSION "Abwasser"
STYLE
COLOR 255 128 0
END
STYLE
WIDTH 2
ANTIALIAS TRUE
END
END
CLASS
NAME "Diverse Abwasseraufgaben"
STYLE
SYMBOL "schraffur_orange"
END
EXPRESSION "Diverse Abwasseraufgaben"
STYLE
WIDTH 2
ANTIALIAS TRUE
END
END
CLASS
NAME "Kein Abwasser"
EXPRESSION "Kein Abwasser"
STYLE
WIDTH 2
ANTIALIAS TRUE
END
END
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_title" "Abwasser"
END
END
Bye, TDS
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 26.03.2014 21:50, schrieb jt at mapmedia.de:
> Hi,
> Referring to your signatur: rtfm ;)
> Try http://mapserver.org/de/mapfile/join.htm
> Join streets_main with the dbf of streets_sub. Read the doc carefuly,
> it's a bit tricky.
> You may find a working example under
> http://mapmedia.de/downloads/viewcategory/5-vortraege (
> Workshop_umn...)
> Jörg
> On Wed, 26 Mar 2014 20:58:17 +0100, TDS wrote:
>> Hello,
>> is it possible to join two layers in GetFeatureInfo with same
>> template and same shape file to output only one combined html file?
>> Example:
>> Streets_Main => streets.shp => template.html
>> Streets_Sub => streets.shp => template.html
>> OUTPUT:
>> Current:
>> Output for Streets_Mains
>> Output for Streets_Sub
>> Wish:
>> Streets_Mains unique id Streets_sub (e.g. main street and sub street
>> have both id=1 in shape file)
>> Bye, TDS
>> 1+1=10
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140327/4b1a902a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140327/4b1a902a/attachment-0001.png>
