[mapserver-users] Combine GetFeatureInfo for layers with same data source
Jörg Thomsen
jt at mapmedia.de
Thu Mar 27 05:58:30 PDT 2014
okay, join is not what you need, sorry.
Would it work for you if only one of the two layers is queryable?
At the moment I have no idea...
Jörg
Am 27.03.2014 11:57, schrieb TDS:
> Hello,
> I've read this and I'm confused of how it can work...
> ONE-TO-ONE or ONE-TO-MANY or ... I want to have a solution *scream* If
> both layers are queried it should be one table, because the date is the
> same. Only the class item differs.
> Example Mapfile:
> LAYER
> STATUS on
> NAME "Trinkwasserversorgung"
> TYPE POLYGON
> DATA "wv_wilster_84.shp"
> DUMP true
> TOLERANCE 3
> TOLERANCEUNITS pixels
> CLASSITEM "TW"
> HEADER "templates/header.html"
> TEMPLATE "templates/template.html"
> FOOTER "templates/footer.html"
> JOIN
> NAME "Wasser"
> TABLE "wv_wilster_84.dbf"
> FROM "Id"
> TO "Id"
> TYPE ONE-TO-ONE
> END
> CLASS
> NAME "Trinkwasser"
> EXPRESSION "Trinkwasser"
> STYLE
> COLOR 130 192 255
> END
> STYLE
> OUTLINECOLOR 120 120 120
> WIDTH 2
> ANTIALIAS TRUE
> END
> END
> CLASS
> NAME "Selbstversorger"
> STYLE
> SYMBOL "im_schraffur"
> END
> EXPRESSION "Selbstversorger"
> STYLE
> WIDTH 2
> ANTIALIAS TRUE
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_title" "Verbandsgebiet"
> "wms_title metadata" ""
> "wms_include_items" "all"
> "wms_srs" "EPSG:4326 EPSG:54004 EPSG:41001
> EPSG:31467 EPSG:31468"
> END
> END
> LAYER
> STATUS on
> NAME "Abwasserentsorgung"
> TYPE POLYGON
> DUMP true
> TOLERANCE 3
> CLASSITEM "AW"
> JOIN
> NAME "Wasser"
> FROM "Id"
> TO "Id"
> TYPE ONE-TO-ONE
> END
> CLASS
> NAME "Abwasser"
> EXPRESSION "Abwasser"
> STYLE
> COLOR 255 128 0
> END
> STYLE
> WIDTH 2
> ANTIALIAS TRUE
> END
> END
> CLASS
> NAME "Diverse Abwasseraufgaben"
> STYLE
> SYMBOL "schraffur_orange"
> END
> EXPRESSION "Diverse Abwasseraufgaben"
> STYLE
> WIDTH 2
> ANTIALIAS TRUE
> END
> END
> CLASS
> NAME "Kein Abwasser"
> EXPRESSION "Kein Abwasser"
> STYLE
> WIDTH 2
> ANTIALIAS TRUE
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_title" "Abwasser"
> END
> END
> Bye, TDS
> mailto:tds at tds-net.de
> 1+1=10
> You have a question? - 42 or RTFM.
> Am 26.03.2014 21:50, schrieb jt at mapmedia.de:
>> Hi,
>> Referring to your signatur: rtfm ;)
>> Try http://mapserver.org/de/mapfile/join.htm
>> Join streets_main with the dbf of streets_sub. Read the doc carefuly,
>> it's a bit tricky.
>> You may find a working example under
>> http://mapmedia.de/downloads/viewcategory/5-vortraege (
>> Workshop_umn...)
>> Jörg
>> On Wed, 26 Mar 2014 20:58:17 +0100, TDS wrote:
>>> Hello,
>>> is it possible to join two layers in GetFeatureInfo with same
>>> template and same shape file to output only one combined html file?
>>> Example:
>>> Streets_Main => streets.shp => template.html
>>> Streets_Sub => streets.shp => template.html
>>> OUTPUT:
>>> Current:
>>> Output for Streets_Mains
>>> Output for Streets_Sub
>>> Wish:
>>> Streets_Mains unique id Streets_sub (e.g. main street and sub street
>>> have both id=1 in shape file)
>>> Bye, TDS
>>> 1+1=10
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
