[mapserver-users] Combine GetFeatureInfo for layers with same data source
TDS
tds at tds-net.de
Thu Mar 27 06:03:46 PDT 2014
Hello,
that's the problem. The user should select one or both of them. If both,
all two layer names are send in the QUERY_LAYERS inquiry - like it should.
Bye, TDS
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 27.03.2014 13:58, schrieb Jörg Thomsen:
> Hi,
> okay, join is not what you need, sorry.
> Would it work for you if only one of the two layers is queryable?
> At the moment I have no idea...
> Jörg
> Am 27.03.2014 11:57, schrieb TDS:
>> Hello,
>> I've read this and I'm confused of how it can work...
>> ONE-TO-ONE or ONE-TO-MANY or ... I want to have a solution *scream* If
>> both layers are queried it should be one table, because the date is the
>> same. Only the class item differs.
>> Example Mapfile:
>> LAYER
>> STATUS on
>> NAME "Trinkwasserversorgung"
>> TYPE POLYGON
>> DATA "wv_wilster_84.shp"
>> DUMP true
>> TOLERANCE 3
>> TOLERANCEUNITS pixels
>> CLASSITEM "TW"
>> HEADER "templates/header.html"
>> TEMPLATE "templates/template.html"
>> FOOTER "templates/footer.html"
>> JOIN
>> NAME "Wasser"
>> TABLE "wv_wilster_84.dbf"
>> FROM "Id"
>> TO "Id"
>> TYPE ONE-TO-ONE
>> END
>> CLASS
>> NAME "Trinkwasser"
>> EXPRESSION "Trinkwasser"
>> STYLE
>> COLOR 130 192 255
>> END
>> STYLE
>> OUTLINECOLOR 120 120 120
>> WIDTH 2
>> ANTIALIAS TRUE
>> END
>> END
>> CLASS
>> NAME "Selbstversorger"
>> STYLE
>> SYMBOL "im_schraffur"
>> END
>> EXPRESSION "Selbstversorger"
>> STYLE
>> WIDTH 2
>> ANTIALIAS TRUE
>> END
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> METADATA
>> "wms_title" "Verbandsgebiet"
>> "wms_title metadata" ""
>> "wms_include_items" "all"
>> "wms_srs" "EPSG:4326 EPSG:54004 EPSG:41001
>> EPSG:31467 EPSG:31468"
>> END
>> END
>> LAYER
>> STATUS on
>> NAME "Abwasserentsorgung"
>> TYPE POLYGON
>> DUMP true
>> TOLERANCE 3
>> CLASSITEM "AW"
>> JOIN
>> NAME "Wasser"
>> FROM "Id"
>> TO "Id"
>> TYPE ONE-TO-ONE
>> END
>> CLASS
>> NAME "Abwasser"
>> EXPRESSION "Abwasser"
>> STYLE
>> COLOR 255 128 0
>> END
>> STYLE
>> WIDTH 2
>> ANTIALIAS TRUE
>> END
>> END
>> CLASS
>> NAME "Diverse Abwasseraufgaben"
>> STYLE
>> SYMBOL "schraffur_orange"
>> END
>> EXPRESSION "Diverse Abwasseraufgaben"
>> STYLE
>> WIDTH 2
>> ANTIALIAS TRUE
>> END
>> END
>> CLASS
>> NAME "Kein Abwasser"
>> EXPRESSION "Kein Abwasser"
>> STYLE
>> WIDTH 2
>> ANTIALIAS TRUE
>> END
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> METADATA
>> "wms_title" "Abwasser"
>> END
>> END
>> Bye, TDS
>> 1+1=10
>> Am 26.03.2014 21:50, schrieb jt at mapmedia.de:
>>> Hi,
>>> Referring to your signatur: rtfm ;)
>>> Try http://mapserver.org/de/mapfile/join.htm
>>> Join streets_main with the dbf of streets_sub. Read the doc carefuly,
>>> it's a bit tricky.
>>> You may find a working example under
>>> http://mapmedia.de/downloads/viewcategory/5-vortraege (
>>> Workshop_umn...)
>>> Jörg
>>> On Wed, 26 Mar 2014 20:58:17 +0100, TDS wrote:
>>>> Hello,
>>>> is it possible to join two layers in GetFeatureInfo with same
>>>> template and same shape file to output only one combined html file?
>>>> Example:
>>>> Streets_Main => streets.shp => template.html
>>>> Streets_Sub => streets.shp => template.html
>>>> OUTPUT:
>>>> Current:
>>>> Output for Streets_Mains
>>>> Output for Streets_Sub
>>>> Wish:
>>>> Streets_Mains unique id Streets_sub (e.g. main street and sub street
>>>> have both id=1 in shape file)
>>>> Bye, TDS
>>>> 1+1=10
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140327/0f545d7a/attachment.html>
