[mapserver-users] Tutorial examples - Section4 failing
Krishna Priya Patury
krishna.patury at gmail.com
Thu May 1 10:47:10 PDT 2014
Hi There,
I have Mapserver 6.0.3 installed on a Mac and installation the tutorial
code(http://mapserver.org/id/tutorial/index.html) on it. I am however
unable to get the Sections 3and 4 running. There seems to be a problem with
the map files? or so it seems because I pass in example2's map file the
page comes up fine. Nothing useful in the apache logs except the below
message.
[Thu May 01 13:39:22 2014] [error] [client ::1] Premature end of script
headers: mapserv, referer:
http://localhost/~xxx/apps/tutorial/htdocs/section3.html
Works:
http://localhost/cgi-bin/mapserv?layer=+&mode=browse&submit=Refresh&zoom=0&imgxy=200.0+150.0&imgext=174061.632107+-380354.677260+1514809.722411+624366.322743&map=%2FUsers%2Fkrishnapatury%2FSites%2Fapps%2Ftutorial%2Fhtdocs%2Fexample2.map&root=%2F%7Ekrishnapatury%2Fapps%2Ftutorial&program=%2Fcgi-bin%2Fmapserv&map_web=template+example3-1.html
Does not work:
http://localhost/cgi-bin/mapserv?layer=+&mode=browse&submit=Refresh&zoom=0&imgxy=200.0+150.0&imgext=174061.632107+-380354.677260+1514809.722411+624366.322743&map=%2FUsers%2Fkrishnapatury%2FSites%2Fapps%2Ftutorial%2Fhtdocs%2Fexample3.map&root=%2F%7Ekrishnapatury%2Fapps%2Ftutorial&program=%2Fcgi-bin%2Fmapserv&map_web=template+example3-1.html
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140501/73ff1d58/attachment-0001.html>
