[mapserver-users] Label once per shape
Lime, Steve D (MNIT) Steve.Lime at state.mn.us
Tue May 13 08:19:11 PDT 2014
Try adding this to the States layer:
  PROCESSING 'LABEL_NO_CLIP=1'
This tells MapServer to compute a label point before clipping the geometry. Basically it fixes the label point.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of T_Junky
Sent: Tuesday, May 13, 2014 10:09 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Label once per shape
I am using MapServer and Openlayers to draw my maps.
The problem I am having is that a lot of my layers are tiled and I need to label just the shape displayed and not the tile(which is what's happening now)...
Here's an example of what's happening.
<http://osgeo-org.1560.x6.nabble.com/file/n5140026/MSLabelExample.jpg>
My Map file looks like this...
MAP
  IMAGETYPE      PNG24
  CONFIG "PROJ_LIB" "C:/Program Files/MapServer/projlib/"
  EXTENT         -180 -90 180 90
  SIZE           256 256
  FONTSET "C:/Program Files/MapServer/content/fontset.txt"
  IMAGECOLOR     255 255 255
  TRANSPARENT ON
  PROJECTION
     AUTO
  END
	LAYER
  		NAME "States"
  		TYPE POLYGON
  		STATUS ON
		LABELCACHE ON
  		CONNECTIONTYPE PLUGIN
  		PLUGIN "msplugin_mssql2008.dll"
  		CONNECTION
"server=stbisqlr3.dvcorp.rcis.com,5208;uid=Mapping01D;pwd=9GreenSnap#4D;Initial
Catalog=NATIONALDB;Integrated Security=False"
  		DATA "shape(geography),ST_NAME_MC from NATIONALDB.sde.STATES USING INDEX S11_idx USING UNIQUE STATES_ID USING SRID=4269"
		LABELITEM    "ST_NAME_MC"
		CLASS
			STYLE
			 OUTLINECOLOR 000 153 000
			 WIDTH 3
			END
			 LABEL
				COLOR 000 153 000
				TYPE TRUETYPE
				FONT Arial
				SIZE 12
				ANTIALIAS TRUE
				POSITION AUTO
				PARTIALS FALSE
				MINDISTANCE 2000
				MINSCALEDENOM 20.00
			END
		END
    	PROJECTION
     		 AUTO
    	END
  	END
END
View this message in context: http://osgeo-org.1560.x6.nabble.com/Label-once-per-shape-tp5140026.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
