[mapserver-users] Windows Installation
Alex Mandel
tech_dev at wildintellect.com
Wed May 14 13:16:26 PDT 2014
On 05/14/2014 12:49 PM, trailway wrote:
> Jerome, thanks for the comment "you should use the 32 bit installer as the
> packages are more up to date on this version".
> There are different set of packages available when you run the 32 bit
> installer versus the 64 bit installer. You can see the differences here:
> http://download.osgeo.org/osgeo4w/x86_64/release/
> http://download.osgeo.org/osgeo4w/x86/release/
> In particular, Apache related packages only show up in the 32 bit installer.
> That seems very confusing to me. My goal is to run this on a 64 bit server
> machine, e.g. Windows Server 2012, running in Amazon.
> Which installer should I use?
> If using OSGeo4W is not best practices then I'd appreciate that feedback.
It's just because no one has gotten around to supplying the 64bit
windows Apache binaries. Apache.org does not appear to make them.
You can probably combine this with osgeo4w
https://www.apachelounge.com/download/win64/
Enjoy,
Alex
