[mapserver-users] Windows Installation
Donald Kerr
donald.kerr at dkerr.co.uk
Thu May 15 12:49:38 PDT 2014
I have experience of setting up mapserver/openlayers with IIS/FastCGI: older
IIS versions through to the latest. Feel free to fire of specific questions
and I will see if I can help. There are more issues with the later versions
of IIS since a lot of stuff is turned off by default e.g. certain mime types
like kml etc.
Regards,
Donald
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of trailway
Sent: 15 May 2014 20:44
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Windows Installation
Thanks to everyone who responded. I appreciate all the advice.
James - It is still confusing to me how exactly to configure IIS. I have
found multiple sets of instructions. For me, Apache is an option and I was
thinking that it might be easier to configure and use in conjunction with
Map Server.
Richard - Thanks for note on using LINUX. Unfortunately, I have other
software which is Windows only so that isn't an option for me at this time.
I noticed on your website that you have deployed Map Server on Amazon. If
you any lessons learned from that then I'd sure appreciate it.
After writing this I found that I had overlooked the statement "32bit/64bit
don't contain the same set of packages/versions (compare) (purple is 32 bit
only)" on the page:
http://trac.osgeo.org/osgeo4w/
That gives you this link:
http://download.osgeo.org/osgeo4w/versions_diff-x86-x86_64.html
There are a lot of differences.
trailway at gmail dot com
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Windows-Installation-tp5140281p5140587.h
tml
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2014.0.4577 / Virus Database: 3950/7500 - Release Date: 05/15/14
