[mapserver-users] EPSG: 3844 problem
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Fri May 16 08:47:46 PDT 2014
EPSG:3844 seems to be a system with Northing-Easting coordinate axis order:
http://epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::3844&reportDetail=short&style=urn:uuid:report-style:default-with-code&style_name=OGP%20Default%20With%20Code&title=EPSG:3844
Two solutions:
- Use WMS 1.1.1
- Flip the coordinates in the BBOX of WMS 1.3.0
-Jukka Rahkonen-
Petr Suk wrote:
hi there,
I am trying to set up WMS with EPSG:3844. The source data are GTiffs (EPSG:3844). The problem is, that GetMap request sends only blank images when 3844 is used. If the request is with EPSG:4326 everything is fine and the transformation is OK too.
The mapfile looks like:
MAP
NAME Romania_Orthophoto
SIZE 400 300
EXTENT 419332.586421 240848.815804 459780.109320 259741.205149
UNITS METERS
SHAPEPATH "//data/romania/Olt/"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
WEB
METADATA
"wms_title" "Romania OrthoPhoto"
"wms_onlineresource" "http://localhost/cgi-bin/wms/romania"
"wms_srs" "EPSG:4326 EPSG:3844"
"wms_enable_request" "*"
"wms_extent" "419332.586421 240848.815804 459780.109320 259741.205149"
END
END
PROJECTION
"init=epsg:3844"
END
LAYER
NAME "orthophoto"
STATUS ON
TILEINDEX olt.shp
OFFSITE 255 255 255
OPACITY 85
TYPE RASTER
METADATA
"wms_title" "orthophoto"
END
END
END
GetMap looks like:
SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=419102.35417775972746313,240475.32843947352375835,459895.23908429278526455,260119.92758433445123956&CRS=EPSG:3844&WIDTH=1521&HEIGHT=731&LAYERS=orthophoto&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE
I am running mapserver 6.2.1 on Ubuntu 12.04 with proj 4.8.0 and gdal 1.10
Thanks a lot for any hints.
Petr
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140516/8197a477/attachment.html>
