[mapserver-users] WFS query slow on large postgis table (and small table disappointing as well)
Even Rouault
even.rouault at spatialys.com
Tue Nov 4 09:20:27 PST 2014
Le mardi 04 novembre 2014 17:27:31, deduikertjes a écrit :
> Hi Steve, List,
> Hmm, I compiled mapserver from sources (GitHub Master). Actually that
> was not that bad, all tough I did not find out how to run the mapserver
> from ubuntu packages next to the one I compiled myself.
> The new mapserver is working ... a bit.
> The new mapserver doesn't support custom dimensions (yet ?) which I do
> use. So, for now I've removed that from the client side requests and
> getmap requests are fine .
> Then do a simple query like:
> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <wfs:Query typeName="hb:jan2014_high" srsName="EPSG:900913"
> xmlns:hb="http://maps.md2.com/schemas/hb_wfs.xsd">
> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
> <ogc:Intersects>
> <ogc:PropertyName></ogc:PropertyName>
> <gml:Polygon
> xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:900913">
> <gml:exterior>
> <gml:LinearRing>
> <gml:posList>493014.59839229
> 6795936.8942158 493014.59839229 6796022.885872601 493102.97870623
> 6795936.8942158 493014.59839229 6795936.8942158</gml:posList>
> </gml:LinearRing>
> </gml:exterior>
> </gml:Polygon>
> </ogc:Intersects>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> Resulting in an error:
> msWFSGetFeature(): WFS server error. Invalid or Unsupported FILTER in
> GetFeature : <Filter ogc="http://www.opengis.net/ogc"> <Intersects>
> <PropertyName /> <Polygon gml="http://www.opengis.net/gml"
> srsName="EPSG:900913"> <exterior> <LinearRing> <posList>492858.14135005
> 6795805.518073499 492858.14135005 6796116.0435008 493197.33066301
> 6796116.0435008 493197.33066301 6795805.518073499 492858.14135005
> 6795805.518073499</posList> </LinearRing> </exterior> </Polygon>
> </Intersects> </Filter>
> (Mapserver 6.4 accepts this query and returns a result (albeit taking
> long)).
The issue is the empty content in <PropertyName>. Setting it to anything non
empty should fix it. We are perhaps more sensitive to that now that in previous
versions.
> A simple query like this works:
> http://xxxxx/maps/xxxx/rc1/services/basic/default.map?service=WFS&version=1
> .1.0&request=DescribeFeatureType&typeName=jan2014_high"
> <wfs:Query typeName="feature:jan2014_high" srsName="EPSG:900913">
> <ogc:And>
> <ogc:BBOX>
> <ogc:PropertyName>msGeometry</ogc:PropertyName>
> <gml:Envelope xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:900913">
> <gml:lowerCorner>491667.6470239 6795223.3576443</gml:lowerCorner>
> <gml:upperCorner>494192.4576141 6796212.2616977</gml:upperCorner>
> </gml:Envelope>
> </ogc:BBOX>
> <ogc:PropertyIsLessThan>
> <ogc:PropertyName>value</ogc:PropertyName>
> <ogc:Literal>0</ogc:Literal>
> </ogc:PropertyIsLessThan>
> </ogc:And>
> </ogc:Filter>
> </wfs:Query>
> </wfs:GetFeature>
> but that one was already reasonably fast.
> Any pointers very much appreciated.
> MArco
> On 03-11-14 19:06, Lime, Steve D (MNIT) wrote:
> > MapServer 7.0 should fix issues like this. A more general solution to the
> > one presented in #4049 has been added to that version. You might try the
> > development version and see how it goes. I'm surprised simple queries
> > aren't working well though since older versions of MapServer have
> > optimizations specific to PostGIS for those simple cases.
> > Steve
> > -----Original Message-----
> > From: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> > deduikertjes Sent: Monday, November 03, 2014 9:56 AM
> > To: mapserver-users at lists.osgeo.org
> > Subject: [mapserver-users] WFS query slow on large postgis table (and
> > Hi List,
> > I'm experiencing real slow performance when doing WFS queries on a
> > postgis table with about 1500000 records.
> > A simple spatial query (which features in a box) takes about 1 to 2
> > minutes. In postgis the same query takes less than a second. Same story
> > for attribute queries. Indeed on a postgis table with some 60000 records
> > things are still very very slow.
> > WMS on the other hand is flying taking less than a second for rendering
> > most tiles.
> > By using the debug functions I see that mapserver fetches all features in
> > the map extent (set at map level) and then starts filtering feature by
> > feature which takes a long time.
> > I found ticket http://trac.osgeo.org/mapserver/ticket/4049 which seems to
> > be related.
> > Is there any way to speed up this kind of WFS queries? Is there any
> > progress on the ticket?
> > Any help appreciated, MArco
> > View this message in context:
> > http://osgeo-org.1560.x6.nabble.com/WFS-query-slow-on-large-postgis-tabl
> > e-and-small-table-disappointing-as-well-tp5170988.html Sent from the
> > Mapserver - User mailing list archive at Nabble.com.
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
http://www.spatialys.com
