[mapserver-users] WFS query slow on large postgis table (and small table disappointing as well)
mdprive
deduikertjes at xs4all.nl
Tue Nov 4 11:39:51 PST 2014
Even,
Thank you. i'll try to convince my geoext viewer to set a non empty PropertyName. Up till now that proves to be not so easy.
Any hints on the custom dimensions?
Marco
Op 4 nov. 2014 om 18:20 heeft Even Rouault <even.rouault at spatialys.com> het volgende geschreven:
> Le mardi 04 novembre 2014 17:27:31, deduikertjes a écrit :
>> Hi Steve, List,
>> Hmm, I compiled mapserver from sources (GitHub Master). Actually that
>> was not that bad, all tough I did not find out how to run the mapserver
>> from ubuntu packages next to the one I compiled myself.
>> The new mapserver is working ... a bit.
>> The new mapserver doesn't support custom dimensions (yet ?) which I do
>> use. So, for now I've removed that from the client side requests and
>> getmap requests are fine .
>> Then do a simple query like:
>> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
>> version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
>> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>> <wfs:Query typeName="hb:jan2014_high" srsName="EPSG:900913"
>> xmlns:hb="http://maps.md2.com/schemas/hb_wfs.xsd">
>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
>> <ogc:Intersects>
>> <ogc:PropertyName></ogc:PropertyName>
>> <gml:Polygon
>> xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:900913">
>> <gml:exterior>
>> <gml:LinearRing>
>> <gml:posList>493014.59839229
>> 6795936.8942158 493014.59839229 6796022.885872601 493102.97870623
>> 6795936.8942158 493014.59839229 6795936.8942158</gml:posList>
>> </gml:LinearRing>
>> </gml:exterior>
>> </gml:Polygon>
>> </ogc:Intersects>
>> </ogc:Filter>
>> </wfs:Query>
>> </wfs:GetFeature>
>> Resulting in an error:
>> msWFSGetFeature(): WFS server error. Invalid or Unsupported FILTER in
>> GetFeature : <Filter ogc="http://www.opengis.net/ogc"> <Intersects>
>> <PropertyName /> <Polygon gml="http://www.opengis.net/gml"
>> srsName="EPSG:900913"> <exterior> <LinearRing> <posList>492858.14135005
>> 6795805.518073499 492858.14135005 6796116.0435008 493197.33066301
>> 6796116.0435008 493197.33066301 6795805.518073499 492858.14135005
>> 6795805.518073499</posList> </LinearRing> </exterior> </Polygon>
>> </Intersects> </Filter>
>> (Mapserver 6.4 accepts this query and returns a result (albeit taking
>> long)).
> The issue is the empty content in <PropertyName>. Setting it to anything non
> empty should fix it. We are perhaps more sensitive to that now that in previous
> versions.
>> A simple query like this works:
>> http://xxxxx/maps/xxxx/rc1/services/basic/default.map?service=WFS&version=1
>> .1.0&request=DescribeFeatureType&typeName=jan2014_high"
>> <wfs:Query typeName="feature:jan2014_high" srsName="EPSG:900913">
>> <ogc:And>
>> <ogc:BBOX>
>> <ogc:PropertyName>msGeometry</ogc:PropertyName>
>> <gml:Envelope xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:900913">
>> <gml:lowerCorner>491667.6470239 6795223.3576443</gml:lowerCorner>
>> <gml:upperCorner>494192.4576141 6796212.2616977</gml:upperCorner>
>> </gml:Envelope>
>> </ogc:BBOX>
>> <ogc:PropertyIsLessThan>
>> <ogc:PropertyName>value</ogc:PropertyName>
>> <ogc:Literal>0</ogc:Literal>
>> </ogc:PropertyIsLessThan>
>> </ogc:And>
>> </ogc:Filter>
>> </wfs:Query>
>> </wfs:GetFeature>
>> but that one was already reasonably fast.
>> Any pointers very much appreciated.
>> MArco
>> On 03-11-14 19:06, Lime, Steve D (MNIT) wrote:
>>> MapServer 7.0 should fix issues like this. A more general solution to the
>>> one presented in #4049 has been added to that version. You might try the
>>> development version and see how it goes. I'm surprised simple queries
>>> aren't working well though since older versions of MapServer have
>>> optimizations specific to PostGIS for those simple cases.
>>> Steve
>>> -----Original Message-----
>>> From: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
>>> deduikertjes Sent: Monday, November 03, 2014 9:56 AM
>>> To: mapserver-users at lists.osgeo.org
>>> Subject: [mapserver-users] WFS query slow on large postgis table (and
>>> Hi List,
>>> I'm experiencing real slow performance when doing WFS queries on a
>>> postgis table with about 1500000 records.
>>> A simple spatial query (which features in a box) takes about 1 to 2
>>> minutes. In postgis the same query takes less than a second. Same story
>>> for attribute queries. Indeed on a postgis table with some 60000 records
>>> things are still very very slow.
>>> WMS on the other hand is flying taking less than a second for rendering
>>> most tiles.
>>> By using the debug functions I see that mapserver fetches all features in
>>> the map extent (set at map level) and then starts filtering feature by
>>> feature which takes a long time.
>>> I found ticket http://trac.osgeo.org/mapserver/ticket/4049 which seems to
>>> be related.
>>> Is there any way to speed up this kind of WFS queries? Is there any
>>> progress on the ticket?
>>> Any help appreciated, MArco
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/WFS-query-slow-on-large-postgis-tabl
>>> e-and-small-table-disappointing-as-well-tp5170988.html Sent from the
>>> Mapserver - User mailing list archive at Nabble.com.
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Spatialys - Geospatial professional services
> http://www.spatialys.com
