[mapserver-users] WFS query slow on large postgis table (and small table disappointing as well)
Even Rouault
even.rouault at spatialys.com
Tue Nov 4 11:55:19 PST 2014
Le mardi 04 novembre 2014 20:39:51, mdprive a écrit :
> Even,
> Thank you. i'll try to convince my geoext viewer to set a non empty
> PropertyName. Up till now that proves to be not so easy.
> Any hints on the custom dimensions?
I'm not sure what you mean with "custom dimensions"
> Marco
> Op 4 nov. 2014 om 18:20 heeft Even Rouault <even.rouault at spatialys.com> het
volgende geschreven:
> > Le mardi 04 novembre 2014 17:27:31, deduikertjes a écrit :
> >> Hi Steve, List,
> >> Hmm, I compiled mapserver from sources (GitHub Master). Actually that
> >> was not that bad, all tough I did not find out how to run the mapserver
> >> from ubuntu packages next to the one I compiled myself.
> >> The new mapserver is working ... a bit.
> >> The new mapserver doesn't support custom dimensions (yet ?) which I do
> >> use. So, for now I've removed that from the client side requests and
> >> getmap requests are fine .
> >> Then do a simple query like:
> >> <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> >> version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
> >> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> >> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> >> <wfs:Query typeName="hb:jan2014_high" srsName="EPSG:900913"
> >> xmlns:hb="http://maps.md2.com/schemas/hb_wfs.xsd">
> >> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
> >> <ogc:Intersects>
> >> <ogc:PropertyName></ogc:PropertyName>
> >> <gml:Polygon
> >> xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:900913">
> >> <gml:exterior>
> >> <gml:LinearRing>
> >> <gml:posList>493014.59839229
> >> 6795936.8942158 493014.59839229 6796022.885872601 493102.97870623
> >> 6795936.8942158 493014.59839229 6795936.8942158</gml:posList>
> >> </gml:LinearRing>
> >> </gml:exterior>
> >> </gml:Polygon>
> >> </ogc:Intersects>
> >> </ogc:Filter>
> >> </wfs:Query>
> >> </wfs:GetFeature>
> >> Resulting in an error:
> >> msWFSGetFeature(): WFS server error. Invalid or Unsupported FILTER in
> >> GetFeature : <Filter ogc="http://www.opengis.net/ogc"> <Intersects>
> >> <PropertyName /> <Polygon gml="http://www.opengis.net/gml"
> >> srsName="EPSG:900913"> <exterior> <LinearRing> <posList>492858.14135005
> >> 6795805.518073499 492858.14135005 6796116.0435008 493197.33066301
> >> 6796116.0435008 493197.33066301 6795805.518073499 492858.14135005
> >> 6795805.518073499</posList> </LinearRing> </exterior> </Polygon>
> >> </Intersects> </Filter>
> >> (Mapserver 6.4 accepts this query and returns a result (albeit taking
> >> long)).
> > The issue is the empty content in <PropertyName>. Setting it to anything
> > non empty should fix it. We are perhaps more sensitive to that now that
> > in previous versions.
> >> A simple query like this works:
> >> http://xxxxx/maps/xxxx/rc1/services/basic/default.map?service=WFS&versio
> >> n=1 .1.0&request=DescribeFeatureType&typeName=jan2014_high"
> >> <wfs:Query typeName="feature:jan2014_high" srsName="EPSG:900913">
> >> <ogc:And>
> >> <ogc:BBOX>
> >> <ogc:PropertyName>msGeometry</ogc:PropertyName>
> >> <gml:Envelope xmlns:gml="http://www.opengis.net/gml"
> >> srsName="EPSG:900913"> <gml:lowerCorner>491667.6470239
> >> 6795223.3576443</gml:lowerCorner> <gml:upperCorner>494192.4576141
> >> 6796212.2616977</gml:upperCorner> </gml:Envelope>
> >> </ogc:BBOX>
> >> <ogc:PropertyIsLessThan>
> >> <ogc:PropertyName>value</ogc:PropertyName>
> >> <ogc:Literal>0</ogc:Literal>
> >> </ogc:PropertyIsLessThan>
> >> </ogc:And>
> >> </ogc:Filter>
> >> </wfs:Query>
> >> </wfs:GetFeature>
> >> but that one was already reasonably fast.
> >> Any pointers very much appreciated.
> >> MArco
> >> On 03-11-14 19:06, Lime, Steve D (MNIT) wrote:
> >>> MapServer 7.0 should fix issues like this. A more general solution to
> >>> the one presented in #4049 has been added to that version. You might
> >>> try the development version and see how it goes. I'm surprised simple
> >>> queries aren't working well though since older versions of MapServer
> >>> have optimizations specific to PostGIS for those simple cases.
> >>> Steve
> >>> -----Original Message-----
> >>> From: mapserver-users-bounces at lists.osgeo.org
> >>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> >>> deduikertjes Sent: Monday, November 03, 2014 9:56 AM
> >>> To: mapserver-users at lists.osgeo.org
> >>> Subject: [mapserver-users] WFS query slow on large postgis table (and
> >>> Hi List,
> >>> I'm experiencing real slow performance when doing WFS queries on a
> >>> postgis table with about 1500000 records.
> >>> A simple spatial query (which features in a box) takes about 1 to 2
> >>> minutes. In postgis the same query takes less than a second. Same story
> >>> for attribute queries. Indeed on a postgis table with some 60000
> >>> records things are still very very slow.
> >>> WMS on the other hand is flying taking less than a second for rendering
> >>> most tiles.
> >>> By using the debug functions I see that mapserver fetches all features
> >>> in the map extent (set at map level) and then starts filtering feature
> >>> by feature which takes a long time.
> >>> I found ticket http://trac.osgeo.org/mapserver/ticket/4049 which seems
> >>> to be related.
> >>> Is there any way to speed up this kind of WFS queries? Is there any
> >>> progress on the ticket?
> >>> Any help appreciated, MArco
> >>> View this message in context:
> >>> http://osgeo-org.1560.x6.nabble.com/WFS-query-slow-on-large-postgis-tab
> >>> l e-and-small-table-disappointing-as-well-tp5170988.html Sent from the
> >>> Mapserver - User mailing list archive at Nabble.com.
> >>> _______________________________________________
> >>> mapserver-users mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
http://www.spatialys.com
