[mapserver-users] Annotation label with styleitem auto uses bitmap font
Jelmer Baas
baas at speerit.nl
Wed Nov 5 12:39:28 PST 2014
Hi Humberto,
Thanks for the quick reply.
I have not tried any encoding setting, because it's obviously using the bitmap font. Or would that force MapServer to use a TTF font? I'm also not sure where to add the "FONT" property. On the class? Or Layer? I tried both, had no effect.
I believe I may have a bigger problem, maybe MapServer is falling back to the built-in font because it can't open the TTF files, but I have no idea how to test that (or confirm or deny my suspicions, because I can't find any debugging / logging info).
Regards,
Jelmer
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Humberto Cereser Ibanez
Sent: woensdag 5 november 2014 17:49
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Annotation label with styleitem auto uses bitmap font
Hi Jelmer,
On Wed, 2014-11-05 at 15:30 +0000, Jelmer Baas wrote:
> - Setting class.label properties; this has been removed in 6.2
Did you try set LABEL properties:
FONT to TRUETYPE and
ENCODING to "UTF8" or something like that?
Regards,
