[mapserver-users] Annotation label with styleitem auto uses bitmap font
Humberto Cereser Ibanez
humberto at pastoraldacrianca.org.br
Thu Nov 6 04:34:19 PST 2014
Hi Jelmer,
On Wed, 2014-11-05 at 20:39 +0000, Jelmer Baas wrote:
> Hi Humberto,
> Thanks for the quick reply.
> I have not tried any encoding setting, because it's obviously using the bitmap font. Or would that force MapServer to use a TTF font? I'm also not sure where to add the "FONT" property. On the class? Or Layer? I tried both, had no effect.
My environment is another that your.
I use PhpMapscript and PostgreSQL/Postgis.
But perhaps these settings from my mapfile will be useful to clarifying:
MAP
FONTSET "../fonts/msfontset.txt"
LAYER
labelitem obj_name
CLASS
NAME "Better"
expression ([range] = 1)
STYLE
width 2
color 0 255 0
OUTLINECOLOR 15 15 15
END # Style
LABEL
COLOR 15 15 15
SIZE 8
POSITION auto
mindistance 4
FONT "FreeSans"
type TRUETYPE
ENCODING "UTF8"
END #LABEL
END # Class Better
CLASS
Next, the path for FreeSans at msfontset.txt file:
FreeSans sfd/FreeSans.ttf
And, at the mapfile's directory:
$ ls -l ../fonts/sfd/
-rwxr-xr-x 1 humberto humberto 264072 Sep 30 11:58 FreeSans.ttf
I get the labelitem 'obj_name' and the value tested on the expression
'range' from a PostgreSQL/Postgis query.
> I believe I may have a bigger problem, maybe MapServer is falling back to the built-in font because it can't open the TTF files, but I have no idea how to test that (or confirm or deny my suspicions, because I can't find any debugging / logging info).
Did you looked to Web Server's logs or run the utility command line
'shp2img'?
http://mapserver.org/utilities/shp2img.html
Good luck,
Humberto
