[mapserver-users] WFS query slow on large postgis table (and small table disappointing as well)
thomas bonfort
thomas.bonfort at gmail.com
Fri Nov 7 00:42:40 PST 2014
Yes Marco, Please open a ticket for this.
thanks,
thomas
On 7 November 2014 09:34, deduikertjes <DeDuikertjes at xs4all.nl> wrote:
> Ok, with all the help I came to the following results:
> Compile the current development version (6.5-dev) from GitHub & Install.
> Results:
> Simple Spatial WFS queries require a non-empty
> <ogc:PropertyName></ogc:PropertyName>.
> Setting it too <ogc:PropertyName>foo</ogc:PropertyName> proved to be
> sufficient.
> Query speed is indeed very fast now.
> Using WMS-dimensions as described on
> http://mapserver.org/ogc/wms_dimension.html does work in
> 6.4 but not in 6.5-dev. As I have need for them I recompiled mapserver
> with a
> -DCMAKE_INSTALL_PREFIX=/usr/local/bin switch so I can run mapserver 6.4
> en 6.5-dev next to each
> other. GetMap requests are routed to mapserver 6.4 and GetFeature
> requests are routed to 6.5-dev.
> Using the WMS-dimensons on 6.5-dev yields the following error:
> <ServiceExceptionReport version="1.1.1"><ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named 'jan2014_low'.
> msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR:
> operator does not exist: >= numeric
> LINE 1: ...32.505600397 6790506.21879132))',900913) and (((( >= 0.90000...
> HINT: No operator matches the given name and argument type(s). You might
> need to add explicit type casts.
> </ServiceException></ServiceExceptionReport>
> Its seems that the dimension parameter is not inserted in the layer filter
> expression.
> Should I create a bug report for this?
> MArco
> View this message in context: http://osgeo-org.1560.x6.nabble.com/WFS-query-slow-on-large-postgis-table-and-small-table-disappointing-as-well-tp5170988p5171806.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
