[mapserver-users] Σχετ: Installation of Mapserver 6.4.1
Samuel Mesa
samuelmesa at gmail.com
Mon Nov 10 11:34:50 PST 2014
What distribution of Linux you are using Stefanos?. I think you could
use a package manager to install dependencies and Mapserver.
El lun, 10 de nov 2014 a las 1:04 PM, Stefanos Anastasiou
<emperor_stef at yahoo.gr> escribió:
> Hello Samuel..!!!
> No I'm getting the following error:
> CMake Error at CMakeLists.txt:49 (message):
> GEOS library/component/dependency could not be found.
> -- Could NOT find SVG (missing: SVG_LIBRARY SVG_INCLUDE_DIR)
> -- Could NOT find SVGCAIRO (missing: SVGCAIRO_LIBRARY
> SVGCAIRO_INCLUDE_DIR)
> SVGCAIRO library/component/dependency could not be found.
> Could NOT find GDAL (missing: GDAL_LIBRARY GDAL_INCLUDE_DIR)
> CMake Error at CMakeLists.txt:567 (message):
> GDAL library could not be found and is needed for OGR support.
> Found CURL: /usr/lib/i386-linux-gnu/libcurl.so (found version
> "7.35.0")
> CMake Error at CMakeLists.txt:60 (message):
> CLIENT_WMS support requires GDAL support, however GDAL support has
> been
> disabled.
> CLIENT_WFS support requires OGR support, however OGR support has
> been
> disabled.
> WFS support requires OGR support, however OGR support has been
> disabled.
> KML support requires LIBXML2 support, however LIBXML2 support has
> been
> disabled.
> SOS support requires LIBXML2 support, however LIBXML2 support has
> been
> disabled.
> GIF library/component/dependency could not be found.
> CMake Error at
> /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:108
> (message):
> Could NOT find SWIG (missing: SWIG_EXECUTABLE SWIG_DIR)
> Does is have to do with the compiling of the libraries? I installed
> all libraries and their .dev through the repositories. Does it have
> to do anything?
> Thanks a lot.
> Stefanos
> Στις 10:10 μ.μ. Σάββατο, 8 Νοεμβρίου 2014,
> ο/η "samuelmesa at gmail.com" <samuelmesa at gmail.com> έγραψε:
> Try again decompressing the src and ignore step 2:
> 2. rm CMakeCache.txt CMakeFiles
> regards,
> Samuel Mesa.
> 2014-11-08 14:31 GMT-05:00 Stefanos Anastasiou
> <emperor_stef at yahoo.gr>:
>> Hi Samuel,
>> Thank you for the reply..!!! I'm getting the following error :
>> CMake Error: The source directory
>> "/usr/local/src/mapserver-6.4.1/build" does not appear to contain
>> CMakeLists.txt.
>> Specify --help for usage, or press the help button on the CMake GUI.
>> If I use CMake GUI I get permission error. I've placed the folder in
>> /usr/local/src. What should I do ?
>> Stefanos
>> Στις 3:12 π.μ. Πέμπτη, 6 Νοεμβρίου 2014, ο/η
>> Hi Stefanos, the next is the instructions for compiling Mapserver in
>> Arch Linux [1]:
>> 1. cd to src mapserver
>> 3. mkdir build
>> 4. cd build
>> 5. compiling as:
>> cmake .. -DCMAKE_INSTALL_PREFIX=/usr
>> -DPYTHON_EXECUTABLE=/usr/bin/python2 \
>> -DPYTHON_LIBRARIES=/usr/lib/python2.7 \
>> -DPYTHON_INCLUDE_PATH=/usr/include/python2.7 \
>> -DFRIBIDI_INCLUDE_DIR="/usr/include/glib-2.0;/usr/lib/glib-2.0/include;/usr/include/fribidi"
>> -DWITH_CAIRO=ON \
>> -DWITH_CLIENT_WFS=ON \
>> -DWITH_CLIENT_WMS=ON \
>> -DWITH_CSHARP=OFF \
>> -DWITH_CURL=ON \
>> -DWITH_EXEMPI=OFF \
>> -DWITH_FCGI=ON \
>> -DWITH_FRIBIDI=ON \
>> -DWITH_GD=OFF \
>> -DWITH_GDAL=ON \
>> -DWITH_GENERIC_NINT=OFF \
>> -DWITH_GEOS=ON \
>> -DWITH_GIF=ON \
>> -DWITH_ICONV=ON \
>> -DWITH_JAVA=OFF \
>> -DWITH_KML=ON \
>> -DWITH_LIBXML2=ON \
>> -DWITH_MSSQL2008=OFF \
>> -DWITH_MYSQL=OFF \
>> -DWITH_OGR=ON \
>> -DWITH_ORACLESPATIAL=OFF \
>> -DWITH_ORACLE_PLUGIN=OFF \
>> -DWITH_PERL=OFF \
>> -DWITH_PHP=ON \
>> -DWITH_POINT_Z_M=OFF \
>> -DWITH_POSTGIS=ON \
>> -DWITH_PROJ=ON \
>> -DWITH_PYTHON=ON \
>> -DWITH_RSVG=OFF \
>> -DWITH_RUBY=OFF \
>> -DWITH_SDE=OFF \
>> -DWITH_SDE_PLUGIN=OFF \
>> -DWITH_SOS=ON \
>> -DWITH_SVGCAIRO=ON \
>> -DWITH_THREAD_SAFETY=ON \
>> -DWITH_WCS=ON \
>> -DWITH_WFS=ON \
>> -DWITH_WMS=ON \
>> -DWITH_XMLMAPFILE=OFF \
>> -DFREETYPE_INCLUDE_DIR=/usr/include/freetype2 \
>> 6. make clean && make
>> 7. make install
>> regards,
>> Samuel Mesa.
>> [1] https://aur.archlinux.org/packages/ma/mapserver/PKGBUILD
>> 2014-11-04 17:44 GMT-05:00 Stefanos Anastasiou
>>> Hello.!!
>>> I'm wondering if the installation should be made only with cmake.
>>> Can't someone just use the repos ? I'm trying to use cmake but
>>> getting a lot or errors, probably having to do with the PREFIX
>>> path. So I'm feeling pretty confused. I'm also not that good with
>>> linux file system hierarchy.
>>> Thanks
>>> Stefanos
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> / v \
> / v \
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141110/89092c95/attachment.html>
