[mapserver-users] [mapserver-dev] Configuring TinyOWS with a standard Mapfile in OSGeo4W
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Tue Nov 11 14:43:33 PST 2014
Please send your LAYER. Just to make sure that there are no typos etc. Check also that user you use for making a connection have INSERT/UPDATE/DELETE rights.
How does QGIS behave? Which QGIS version? Can you switch the layer to edit mode? Is just saving the changes that fails?
-Jukka Rahkonen-
samuelmesa wrote
I've tried to create a WFS-T service configuring TinyOWS with a standard Mapfile in OSGeo4W, following the instructions in [1].
The connection is correct but does not enable transccionales operations, example using QGIS Desktop.
Has anyone been able start up the WFS-T service from Mapfile and TinyOWS in OSGeo4W? There are limitations on OSGeo4W to publish the WFS-T service with Mapfile?
regards,
Samuel Mesa.
[1]. http://mapserver.org/tinyows/mapfileconfig.html
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141111/75198c3b/attachment.html>
