[mapserver-users] Debugging mapserver 6.2
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Sep 2 08:58:20 PDT 2014
Check permissions on the file
ls -l /tmp/ms_error.txt
sudo chmod 666 /tmp/ms_error.txt
and try it again from the webserver.
-Steve W
On 9/2/2014 11:27 AM, Antti J. Lind wrote:
> Hi,
> Seems to be plenty of space on /tmp/, only 7% used.
> With shp2img seems to write to correct file
> [Tue Sep 2 18:24:58 2014].520502 msDrawMap(): rendering using
> outputformat named png (AGG/PNG).
> [Tue Sep 2 18:24:59 2014].17303 msDrawMap(): WMS/WFS set-up and query,
> 0.497s
> [Tue Sep 2 18:24:59 2014].19072 msDrawRasterLayerLow(kartta_mk2m):
> entering.
> [Tue Sep 2 18:24:59 2014].34160 msDrawMap(): Layer 0 (kartta_mk2m), 0.017s
> [Tue Sep 2 18:24:59 2014].34341 msDrawRasterLayerLow(watermark): entering.
> [Tue Sep 2 18:24:59 2014].47150 msDrawMap(): Layer 7 (watermark), 0.013s
> [Tue Sep 2 18:24:59 2014].47221 msDrawMap(): Layer 8 (lupa), 0.000s
> [Tue Sep 2 18:24:59 2014].47299 msDrawMap(): Drawing Label Cache, 0.000s
> [Tue Sep 2 18:24:59 2014].47311 msDrawMap() total time: 0.528s
> [Tue Sep 2 18:24:59 2014].879297 msSaveImage(stdout) total time: 0.832s
> [Tue Sep 2 18:24:59 2014].879659 msFreeMap(): freeing map at 0x234f570.
> AJL
> Jeff McKenna kirjoitti 2014-09-02 18:21:
>> On 2014-09-02 12:01 PM, Antti J. Lind wrote:
>>> Hello list,
>>> I try to debug mapserver (version 6.2.2) without success.
>>> I have set on map-file
>>> CONFIG "MS_ERRORFILE" "/tmp/ms_error.txt"
>>> DEBUG 5
>>> and run web-application.
>>> Log file shows up on /tmp-directory, but it's allways empty.
>>> ll /tmp/ms_*
>>> -rw-r--r-- 1 apache apache 0 Sep 2 12:16 /tmp/ms_error.txt
>>> Ideas?
>>> Antti J. Lind
>> You might also use the shp2img commandline utility with the
>> '-all_debug 5' switch.
>> -jeff
> mapserver-users at lists.osgeo.org
