[mapserver-users] Debugging mapserver 6.2
Antti J. Lind
anttij.lind at birdlife.fi
Tue Sep 2 09:14:30 PDT 2014
I can remove file and when running from webserver, it recreated again
and owned by apache with -rw-r--r-- rights.
Same when chmod 666 existing file.
AJL
Stephen Woodbridge kirjoitti 2014-09-02 18:58:
> Check permissions on the file
> ls -l /tmp/ms_error.txt
> sudo chmod 666 /tmp/ms_error.txt
> and try it again from the webserver.
> -Steve W
> On 9/2/2014 11:27 AM, Antti J. Lind wrote:
>> Hi,
>> Seems to be plenty of space on /tmp/, only 7% used.
>> With shp2img seems to write to correct file
>> [Tue Sep 2 18:24:58 2014].520502 msDrawMap(): rendering using
>> outputformat named png (AGG/PNG).
>> [Tue Sep 2 18:24:59 2014].17303 msDrawMap(): WMS/WFS set-up and
>> query,
>> 0.497s
>> [Tue Sep 2 18:24:59 2014].19072 msDrawRasterLayerLow(kartta_mk2m):
>> entering.
>> [Tue Sep 2 18:24:59 2014].34160 msDrawMap(): Layer 0 (kartta_mk2m),
>> 0.017s
>> [Tue Sep 2 18:24:59 2014].34341 msDrawRasterLayerLow(watermark):
>> entering.
>> [Tue Sep 2 18:24:59 2014].47150 msDrawMap(): Layer 7 (watermark),
>> 0.013s
>> [Tue Sep 2 18:24:59 2014].47221 msDrawMap(): Layer 8 (lupa), 0.000s
>> [Tue Sep 2 18:24:59 2014].47299 msDrawMap(): Drawing Label Cache,
>> 0.000s
>> [Tue Sep 2 18:24:59 2014].47311 msDrawMap() total time: 0.528s
>> [Tue Sep 2 18:24:59 2014].879297 msSaveImage(stdout) total time:
>> 0.832s
>> [Tue Sep 2 18:24:59 2014].879659 msFreeMap(): freeing map at
>> 0x234f570.
>> AJL
>> Jeff McKenna kirjoitti 2014-09-02 18:21:
>>> On 2014-09-02 12:01 PM, Antti J. Lind wrote:
>>>> Hello list,
>>>> I try to debug mapserver (version 6.2.2) without success.
>>>> I have set on map-file
>>>> CONFIG "MS_ERRORFILE" "/tmp/ms_error.txt"
>>>> DEBUG 5
>>>> and run web-application.
>>>> Log file shows up on /tmp-directory, but it's allways empty.
>>>> ll /tmp/ms_*
>>>> -rw-r--r-- 1 apache apache 0 Sep 2 12:16 /tmp/ms_error.txt
>>>> Ideas?
>>>> Antti J. Lind
>>> You might also use the shp2img commandline utility with the
>>> '-all_debug 5' switch.
>>> -jeff
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
