[mapserver-users] Oracle layer partially drawn
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Wed Sep 3 02:57:04 PDT 2014
Things to try:
- Check by other means that your Oracle table really has all the data,.
- Keep DEBUG 5 on.
- Try if OGR connection gives the same result.
- Debug OGR connection more by adding CONFIG "CPL_DEBUG" "ON".
- Remove min/maxscaledenoms (even they do not cause the trouble, otherwise you would see nothing).
- Transparency is deprecated, use opacity instead.
- If TRANSPARENCY 100 works it would render totally transparent features and I wonder why you see anything.
- Your wms_extent is more strict than extents of the whole mapfile, try if commenting it out is changing anything.
- Recreate the spatial index in Oracle.
- Check layer extents in Oracle from ALL_SDO_GEOM_METADATA
- Start from the beginning by downloading some data from http://www.naturalearthdata.com/downloads/. Import data into Oracle with ogr2ogr and make a new layer from it. Write down everything you do. If you make the problem easy enough to reproduce it is possible that someone will pay some attention to it.
-Jukka Rahkonen-
Geograma wrote:
> Hello Tike,
> Instead of checking for arcs, I got images with a point layer and the problem is
> also there, so I think that it could be a problem with the number of features to
> draw (too much?), but I do not know hoy to get the number of features drawn
> for the layer.
> The results of the point layer:
> PostGis:
> <http://osgeo-org.1560.x6.nabble.com/file/n5159840/postgis2.png>
> Oracle:
> <http://osgeo-org.1560.x6.nabble.com/file/n5159840/oracle2.png>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Oracle-
> layer-partially-drawn-tp5159828p5159840.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
